plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 14th, 2005, 12:14 PM   #1
DGR
United States
DGR is offline
Micrologix 1100 Ethernet port
I am having diffuculty communicating with a ML 1100 via the ethernet port. I am able to link OK via the serial port. I have RSLogix 500 V 7.0 and RSLinx Pro V 2.5 software. This is a direct link (no network). RSLinx (RSWho)is showing a connection however. The micrologix icon appears along with the IP address I assigned to it. However, when I go to RSLogix and go online I get the "No response from processor at selected path/node!" error. Any suggestions would be appreciated. Thank you.
Old October 14th, 2005, 12:37 PM   #2
panic mode
Canada
panic mode is offline
panic mode's Avatar
rs linx updates are slow and will not nececarily show lost connection without long wait or manual refreshing.
since you are connecting directly to plc, make sure to use
crossover version of ethernet cable. make sure that both
plc and pc have valid addresses and that both are on a same subnet.
then try to ping plc to make sure everything is ok
then start rslinx and configure driver etc.
Old October 14th, 2005, 07:30 PM   #3
Alan Case
Australia
Alan Case is offline
Alan Case's Avatar
You dont need a crossover cable, the standard one works fine. The message you are getting usually means that the program is trying to go online using a path that does not exist at present. ie you last connected serially so it is trying to connect serially.
EITHER in RS Logix go to comms and try "Who Active Go Online" then drill down to find what you want
OR in the tree go to Controller properties, then the Controller Communications tab. There in the driver window select the driver currently in use, ie the ethernet one. You will probably find the serial driver was selected.
The above info will only work if everything else is set up correctly, ie RSLinx can browse the processor with RSwho using the ethernet driver.
Regards Alan Case
Old October 16th, 2005, 12:16 AM   #4
panic mode
Canada
panic mode's Avatar
Quote:
i didn't have chance to try this plc out but unless you use switch or hub you do need crossover. the only other exception is if you use one of few newer laptops that have smarter nics supporting Auto MDI-MDIX
Old October 16th, 2005, 12:41 AM   #5
Alan Case
Australia
Alan Case's Avatar
Hi Panic, I must have on of the newer nic cards. I will keep that in mind if i use something else. Alan Case
Old October 16th, 2005, 09:05 AM   #6
Contr_Conn
United States
Contr_Conn is offline
Contr_Conn's Avatar
I did not get 1100 yet, just ordered last week, but it is possible that it uses Auto MDI-MDIX port. I will verify and let you know.
More and more devices now use Auto MDI-MDIX. Almost every switch you buy today will have it.
Old October 16th, 2005, 12:03 PM   #7
Contr_Conn
United States
Contr_Conn's Avatar
It looks like 1100 does not have Auto MDI-MDIX port.
From the user manual:
When to use straight-through and cross-over cable:
MicroLogix 1100 Ethernet port to 10/100Base-T Ethernet switch cables utilize a straight-through pin-out (1-1, 2-2, 3-3, 6-6).
Direct point-to-point 10/100 Base-T cables connecting the MicroLogix 1100 Ethernet port directly to another Ethernet port (or a computer 10/100Base-T port) require a cross-over pin-out (1-3, 2-6, 3-1, 6-2).
Old October 16th, 2005, 01:09 PM   #8
Ken Roach
United States
Ken Roach is online now
Ken Roach's Avatar
Regarding the original post: if the MicroLogix icon shows up in the RSLinx browse, then RSLinx software is definitely communicating with the controller.
DGR said: "when I go to RSLogix and go online I get the "No response from processor at selected path/node!" error.
It's probably not that the processor is not responding, it's that the "selected path/node" is not right yet.
In RSLogix 500, you must define the "project path" to go online with a controller. The software will remember that path, so if you switch from serial to Ethernet (for example) you have to change the path too.
Instead of selecting Comms -> Go Online (that will use the current path), select Comms -> Who Active Go Online.
When the MicroLogix icon comes up in RSWho, look down in the lower right corner for the 'Apply to Project' checkbox. That will make the RSLogix 500 project use the path you select in RSWho. You will also be able to select the controller and click Download, Upload, or Go Online.
Old October 17th, 2005, 08:30 AM   #9
DGR
United States
DGR is offline
Thanks Ken, going that route worked. I wasn't able to get the "Apply to Project" box to open but I could highlight the Micro and then hit OK and that got me online. Thanks again.
Old May 9th, 2012, 04:48 PM   #10
zimri
Trinidad and Tobago
zimri is offline
Greetings, I have connected my ML1100 PLC to my PC via a straight cable and it appears in RSLINX when I use the ETHIP driver. However when I go to RSLOGIX, although it sees the processor as connected and ready, when I try to go online it tells me that the diagnostics have failed. Have you ever encountered this issue? thank you.
Old May 10th, 2012, 08:59 AM   #11
Sergei Troizky
Canada
Sergei Troizky is offline
Use crosslink cable for direct connection.
Use Ethernet Devices driver (default name ETH-1).
In the RSLinx, got to Communications>Configure CIP Options, and set as shown:
Old May 14th, 2012, 12:02 AM   #12
zimri
Trinidad and Tobago
zimri is offline
Thank you Sergei, got it to work with the cross cable and the modified CIP settings. However the AB_ETHIP crosses out the MicroLogix 1100 even though the ABETH driver works.
This worries me since I need to interface with Citect Scada v7.2 which uses an Allen Bradley driver [ABMLXEIP] to communicate with the PLC. Do you have any ideas on how to get the other driver to work?
Thanks again,
Cheers
Zimri
Old May 14th, 2012, 01:06 PM   #13
zimri
Trinidad and Tobago
zimri is offline
Citect Working
I got Citect to work using the same driver you advised. Thanks for you help Sergei.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1500 and USB Port Comm problem sandymax LIVE PLC Questions And Answers 3 February 8th, 2005 07:29 AM
How To Download AB PLc programm through Ethernet port Shawn LIVE PLC Questions And Answers 4 October 30th, 2004 03:36 PM
How to get a 5/05 into a network using its Ethernet port? Anibal Hernandez LIVE PLC Questions And Answers 8 April 15th, 2004 05:34 AM
Micrologix message passing (over ethernet) jimbo3123 LIVE PLC Questions And Answers 4 April 13th, 2004 06:29 AM
Ethernet Port Numbers? MartinV LIVE PLC Questions And Answers 3 April 4th, 2003 02:29 PM
