This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: May 2004
Failure Pv550 Connection To Laptop
Need Helpppppppppppp Again:
We Just Bought A New Pv550 Cat #2711-k5a2 Rev: B/frn 4.41/firmware Version 4.2. Rs Link Revision 2.30.01(build 48) I Can't Establish Communication Between Pv550 And My Laptop.i Use A 1747-pic Converter To Connect The Two Unit. I Install The Driver For This Converter But When I Go To Rs Link Who'is There Is No Communication Between Pv 550 And My Pc.i Check Comm Setting Of Pv... Node:2 Baudrate 19200 Max Node:31.then I Check My Driver Setting In My Laptop Com1 Baudrate 19200 Thanks Senen |
#2 |
I think you have two possible problems.
1. The driver might not work on your particular computer. THe 1747-PIC/AIC+ driver in RSLinx is notoriously difficult to set up in Windows NT/2000/XP. Search this site for numerous threads about how to troubleshoot this. 2. If you have just the 1747-PIC and PanelView connected together, you will not get communications. The 1747-PIC receives power from a 1747-AIC isolator, or passed through the PanelView from an isolator or an SLC controller, or via a supplementary power supply. Plug in the PanelView to the controller or the network you intend to use it on. Remember that you can use CompactFlash ATA memory cards in a Type II carrier to transfer programs to the PanelView. That helps you eliminate the need for the 1747-PIC in this situation. |
#3 | |
![]() Join Date: Dec 2004
Quote:
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen |
#4 |
hi ken,
iwas able to used memory card to transfer file from panel view and vice versa.i was able to see too the panel view and slc thru rslink comm.on who's 1.i'm still interested why i can't download my file from pc to pv.i'm having an error(2258)..terminal not responding.IS NEW FIRMWARE OF PV HAVE SOMETHING TO DO WITH IT?/BECAUSE I CAN'T SEE THE CAT AND VERSION NUMBER WHEN I SCROLL THE TERMINAL SET UP.OUR OLD PV IS VERSION...3-.09. THANKS AGAIN |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| AB PLC2 connection with new Laptop? | mls1018 | LIVE PLC Questions And Answers | 0 | September 22nd, 2005 08:58 AM |
| SLC 5/03 and PV550 connection using 1747-C20 | diffy | LIVE PLC Questions And Answers | 7 | July 29th, 2005 05:06 PM |
| Failure PanelViews Connection in RSLinx | hhuong | LIVE PLC Questions And Answers | 15 | November 18th, 2004 09:09 AM |
| Ethernet Wireless Connection - OMRON CJ1 PLC's | castro | LIVE PLC Questions And Answers | 1 | August 17th, 2004 04:04 AM |
| laptop connection | maddog1 | LIVE PLC Questions And Answers | 1 | January 15th, 2004 05:15 AM |
