Help needed on Modbus communication
rakeshndas
Dec 2004
Trivandrum
Hello, I use a Fatek FBs series PLC and a TDS F8 inverter from Tek Drive. I'm totally confused on the address mapping for Modbus master command and the modbus table in PLC.
The modbus master command is showing error some times, but drive is not displaying any communication errors. I have given a 0.1s clock pulse as the enable I/P for the master (think to 0->1 transition enables the command).
My requirement is minimum, to make the drive RUN, JOG and set the frequency. But the addresses mentioned in the communication manual of drive and PLC are entirely different. Using the table I'm sending decimal value for frequency and O or 1 for RUN. Is it okay ?
Can any one help me to get the modbus table and communication OK ? the matter is very urgent !
Rakesh
I'm attaching the communication manual for the drive along with this post.
I am looking for a tool to backup/restore all my retentive located data from a wago 750-862 via modbus tcp. The wago address 12,288 equates to MW0.
2,763
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
223
Hi I’m after some help , I have a plc program with a baumer verisens vision camera attached I have got the signals working ect but I have an...
954
Hi all, We are facing synching issues with redundancy module, where the Primary is ending up with disqualified secondary. Normally this would...
621
Hi all, I have got this machine that needs to be up and running soon. This machine has Schneider's Controller and I/O modules, 3 vfd's, 2...
904
