plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 1st, 2005, 02:43 AM   #1
Bart
Belgium
Bart is offline
Bart's Avatar
modicon A120 analog input problems
Hello,
I need to write a simple program for a Modicon A120 plc system, to check if an analog input card (e.g. ADU 205) is working ok.
I have DOLOG AKF software installed on an ancient laptop.
I am able to program digital inputs and outputs, but I can't seem to get the analog card to work.
I have only verry little information on how to program the analog inputs/outputs.
Does anyone know how to program analog outputs on this system?
any help would be greatly appriciated
thanks
Bart.
Old December 1st, 2005, 11:32 AM   #2
Jim Dungar
United States
Jim Dungar is offline
I am not familiar with the software or the specific card you are using, so I don't know the actual commands.
When using the original 984LL software some Modicon analog cards needed to be configured before you could read them. This usually consisted of writing values into specific 4x registers to tell the card what type of analog signal was going to be seen on each channel as well as what channels will be active (this only had to be done once at each power up). Then each time you want to read a value you write a value to a different register to tell the card what channels (up to two at a time) to scan and which 3x register to put the each value into. This allows you to read some inputs at different rates then other inputs. In effect, you need to create your own input multiplexer.
There might be some more information (Modicon has lots of examples for 984LL commands) on your specific card at www.telemecanique.com.
Old December 5th, 2005, 01:25 AM   #3
Bart
Belgium
Bart is offline
Bart's Avatar
Hello,
I have found the sollution to my poblem. Aparently there was something wrong with the hardware. When I put the analog card (ADU 205) in a different slot on the backplane, it works. Now I just need to read the input word for the card and scale it. e.g. when the card is in slot 7, I use the following code (it's in German)
L EW 7.1
T MW 10
This reads the first analog input from the input card on slot 7.
kind regards,
Bart.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Modicon Analog input scaling.. jimdi4 LIVE PLC Questions And Answers 8 June 9th, 2014 07:10 AM
1762-IF2OF2 Analog Input Problem davidgay LIVE PLC Questions And Answers 22 August 14th, 2013 04:25 AM
Analog input issue! NoName LIVE PLC Questions And Answers 9 July 8th, 2004 04:10 AM
AB Analog Input Help GTX LIVE PLC Questions And Answers 2 December 14th, 2003 02:37 PM
Analog Input - Potentiometer Problems Brad B LIVE PLC Questions And Answers 4 February 20th, 2003 02:19 PM
