Allen Bradley RIO
wtakacs
Dec 2005
Ontario
Thanks for your interest!
Does anyone know how to determine the scan frequency of the flexbus remote I/O mechanism. Does it occur asynchronously to the PLC scan time? At the moment I'm only interested in discrete I/O. Its my understanding that analog I/O must be read using BTs. Perhaps I just dont fully understand the mechanism in which case please explain it!
As an example, I have an SLC5/05 with a 1794-SN installed in Rack 0. A 1794-ASB is intalled and connected with blue hose to the SN. There is a 1794-IB16 on a 1794-TB3 with one wired input to a switch.
Any help is appreciated!
The adapter scans its I/O on an independent cycle. The main rack's scanner polls the adapters. The processor gets it's copy of the I/O data table from the scanner module during it's I/O scan cycle. In short, the RIO is updated asynchronously to the program scan. The I/O image that the processor is working with does not change during logic solving (with SLCs and PLC5s anyway). With a PLC5, I have read some old A/B manuals that stated that the change of state of a discrete input, for example, may be reported to the processor up to 125ms after it actually occurs. Likewise for an output bit. It may take up to 125ms after the PLC turns on the output before that information reaches the remote output point. Repeatability of this delay is random. It might be 5ms one time and 100ms the next. The number of remote racks will affect this as well. A/B has worksheets that can help you accurately determine maximum RIO delays in their system design manuals.
This is something to always keep in mind at design time. Always try to put your time critical I/O in the local rack.
Hope this helps.
Paul C.
I have looked through prior threads and think I have found the answer in a 2002 post but I'm going to post my problem anyway and see what you guys...
3,319
2,755
Can someone help me to map the data from 1794ie12 and oe12 modules connected on rio network with a slc 5/05 cpu
2,268
Hello everyone!!! I'm new in this Forum, I'd like to know how to configure this module, I have it for controlLogix, the thing is that I have a...
3,042
Doing a project with RIO and have my program wrote and my panels prewired. Some circumstances have changed and I might be able to add another...
7,711
