plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 1st, 2006, 05:31 AM   #1
Alan Case
Australia
Alan Case is offline
Alan Case's Avatar
Tips.
Hi, I am compiling a list of off-beat tips and trade tricks using products for their unintended purpose.
ie to start the list.
Aeroguard (it is a spray on insect repellant. not sure if it is sold in the USA) is excellent for removing texta marks from painted switchboards.
Anyone else have anymore ato add?
Regards Alan Case
Old January 1st, 2006, 08:14 AM   #2
ndzied1
United States
ndzied1 is offline
ndzied1's Avatar
You might want to check out the Tips & Tricks section of Ron's site:
http://patchn.com/forum1/viewforum.php?f=4
How about using the box end of a wrench for added leverage on an 'L' shaped hex wrench (Allen Wrench). This does take alittle practice
__________________
nOrM
nOrM=Norman Dziedzic Jr.
Your program may do things you never intended/ When the inputs are in a state you never expected.
Old January 1st, 2006, 09:33 AM   #3
elevmike
United States
elevmike is offline
elevmike's Avatar
Quote:
And when you done with that you can use a rag, (origionally intended for wiping grease or oil), and some electrical tape to patch your scrapped knuckels...
__________________
If you think you can do a thing or think you can't do a thing, you're probably right.... Henry Ford
Old January 1st, 2006, 11:30 AM   #4
darrenj
Canada
darrenj is offline
Quote:
Actually mike i find that just the Electrical tape works the best on minor cuts, Something in the glue..?
One other trick is a 3' piece of 1/2" rope as a fish tape puller..you can get a hell of a pull from it and it doesnt twist and bend the fish as pliers do.
Old January 1st, 2006, 12:00 PM   #5
Lancie1
United States
Lancie1 is online now
Lancie1's Avatar
Alan,
In the US, there is a popular insect repellent brand called "Off". I am sure it would remove marks. I have seen PVC pipe cleaner solvent used for that purpose also.
How about all the ways electricians prepare lunch on the job site? Those PVC conduit benders make great hamburger cookers. The residual melted pvc adds a unique flavor, out of this world...
Old January 1st, 2006, 06:50 PM   #6
stasis
United States
stasis is offline
Quote:
Regards Alan Case
Yellow 77 (Idel brand) wire lube makes the best hand cleaner.
linesman pliers are great for removing 1/2" & 3/4" reducing bushings from conduit fittings.
I'll post more later...
Old January 1st, 2006, 06:56 PM   #7
darrenj
Canada
darrenj is offline
Quote:
Originally Posted by Lancie1
Alan,
Dont forget about the "hot dog cooker"..2 nails and male cord end..plug er in for 10-15 seconds and you have a fully cooked hot dog..(Dont touch the dog while cooking!! )..BTW after many trials..brass nails work the best..
Old January 1st, 2006, 07:37 PM   #8
elevmike
United States
elevmike is offline
elevmike's Avatar
Quote:
When I was in the field I just used a pair of channel locks for most all conduit work (except cutting of course), including deburing the inside and outside of the cut ends.
__________________
Old January 1st, 2006, 08:23 PM   #9
darrenj
Canada
darrenj is offline
Trucks rear view mirror...great for seeing inside walls or hard to see MCC boards..
Old January 1st, 2006, 09:41 PM   #10
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
I can list things like this .....
In a pinch if you need to couple an encoder a short piece of rubber tubing and screw hose clamps will work, just be sure to keep the screw part of the clamps 180 degrees apart. These type clamps;
http://www.idealclamp.com/
I have used just about everything for reaming conduit but many years ago I obtained a Klein screwdrive with a conduit reamer built on, these days you can buy the conduit reamer attachment. Goto www.klein-tools.com and look at Part No. 19352, it is good for 1/2, 3/4, and 1 inch. Since a screwdriver is a standard tool this makes it easy to have with you.
I use sandwich bags for storing leads and other items.
I use 3M plastic tape containers to store anything and everything...screws, bolts, nuts, wirenuts, rubber-bands....
Camera film containers are also good for the above.
Screwdriver tips break (especially when used as a chisel etc) but do not throw it away, just a few minutes grinding can transform it into an awl.
I have more, if I get time I will provide them.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old January 2nd, 2006, 03:02 AM   #11
Alan Case
Australia
Alan Case's Avatar
Thanks Ron. I had a look at your site. Quite a few interesting tips.
The hot dog cooker, was that on 110v? and how many blown fuses did it take to figure it out.
Regards Alan Case
Old January 2nd, 2006, 05:09 AM   #12
elevmike
United States
elevmike is offline
elevmike's Avatar
I cant count how many different ways there are to light a ciggerette..but three of them are with the arc welder, grindner, & torch set..I've run into some pretty inovative smokers when they were faced with the absence of a match or lighter...
__________________
Old January 2nd, 2006, 05:12 AM   #13
lanman
Canada
lanman is offline
I use short pieces of spiral wrap to keep my plc cables tidy.
Old January 2nd, 2006, 05:34 AM   #14
plc_padawan
United States
plc_padawan is offline
plc_padawan's Avatar
A lot of times when i'm trying to get a bearing out of a roller or pulley, i'll use a socket of about the same size as the outer or inner race of the bearing. Since sockets increase and decrease incrementally, it's usually pretty easy to find one that will work. If you have to, you can use deep well sockets or even add extensions if you have a long way to push the bearing out. Just do it on something smooth, like an arbor press.
Old January 2nd, 2006, 06:49 AM   #15
Doug-P
United States
Doug-P is offline
Doug-P's Avatar
Duct Tape More Effective than Cryotherapy for Warts
Article Excerpt:
In patients treated with duct tape, 85 percent of the warts completely resolved, compared with 60 percent in the cryotherapy group. These results were statistically significant. Resolution of warts treated with duct tape usually occurred within the first 28 days of therapy. If there was no response within the first two weeks, the warts were unlikely to respond to a longer course of therapy. The main adverse outcomes with duct-tape therapy were difficulty keeping the tape on the wart and minor skin irritation. The main adverse effect in the cryotherapy group was mild to severe pain at the freeze site during and after the treatment.
The authors conclude that duct tape occlusive therapy is more effective than cryotherapy in the treatment of common warts. They also state that duct tape therapy is less expensive and has fewer adverse effects than cryotherapy.
Is this offbeat enough?
__________________
“The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
OT - Tips on Efficiency Jimmie_Ohio LIVE PLC Questions And Answers 2 September 30th, 2005 09:13 PM
any tips 4 programmer to learn PLC? joe2000 LIVE PLC Questions And Answers 4 September 16th, 2005 10:02 AM
any tips? sapoleon LIVE PLC Questions And Answers 0 February 3rd, 2005 02:36 AM
Automation Desktop Tips and Tricks akreel LIVE PLC Questions And Answers 0 October 12th, 2004 09:18 AM
tips on the design of plc programe timlinp@hotmail.com LIVE PLC Questions And Answers 2 October 20th, 2003 02:10 PM
