![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
AB Ultra 3000 DSD FAULT 19
Please help to clear fault # 19 positioning error on Allen Bradley Ultra 3000 Digital Servo Drive using AB Utra Software
Thank You |
#2 | |
![]() ![]() Join Date: Aug 2005
Quote:
![]() Seriously, you started 2 threads, and the sum total of info you gave is you've got an AB Ultra 3000 Servo Drive, and fault #19. Are the cables properly connected? Does the enocder work? Is the drive train operating properly? Do you have the proper motor selected? |
#3 | |
![]() ![]() Join Date: Dec 2004
Quote:
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen |
#4 |
Thank You
Do you think the hardware bad ( Drive ) ? |
#5 |
Hello CroCop
- The Cable are O.K. - The Encoder check Ok with good drive ( Swapped ) - Drive Train O.K. Manually and drive good with swapped drive - Motor configuration are O.K. Thank you for your help |
#6 |
Wally,
You need to describe your original problem and why you have done what you have done. IT seems that changing the drive and swapping things around isn't helping. My experience is this, most maintenance guys will do what you have done without checking the mechanical side of things. IF this was a working system and has been in operation for a while, then more than likely you have a mechanical problem you are overlooking. David
__________________
The PRICE of FREEDOM is not FREE! My son is now a United States Marine and I could not be more proud of what he and others will do to protect our freedoms here at home. |
#7 |
Are you using a series c feedback cable? I had alot of problems with the B series and got a PSA from rockwell stating a problem with the cables.
#8 |
Hello David,
The machine was running fine and just decided to quit due to the cold weather, I swapped to other motor to check for mechanical problem , It ran fine with other good drive, the fault 19 and fault 24 could be some parameter need to change on the Velocity setup and do you know how to manual or auto tune this drive. Thank you for your help |
#9 |
Thank you , I am going to check the cable
#10 |
So Wally, How'd you make out?
#11 |
AB Ultra 3000
Replaced the Ultra 3000 drive , system back up O.K.
Thanks for the help |
#12 |
I am sorta thinking you have overlooked something. You are obviously involved in a maintenance downtime situation. I would be curious what Rockwell finds when you send it in.
David
__________________
#13 |
Hello Dave
Thanks for the help, you were right , due to the maintenance downtime so I could not keep the equipment down any longer , so the quick way is change the drive , It could be connector loosing intermittenly Regards, Wally |
Bookmarks |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
AB Ultra 3000 Digital Servo Drive | WallyPrestone | LIVE PLC Questions And Answers | 5 | April 28th, 2012 02:33 PM |
RSLogix User Fault Routine | jthornton | LIVE PLC Questions And Answers | 17 | October 23rd, 2008 03:55 PM |
AB powerflex I/O comms fault | mrdmrd | LIVE PLC Questions And Answers | 1 | October 26th, 2005 07:46 AM |
AB PLC5/80B RIO Flex IO Fault | corkers | LIVE PLC Questions And Answers | 9 | September 4th, 2004 02:12 AM |
Ab Plc5 Rio Adapter Fault | Simil | LIVE PLC Questions And Answers | 4 | July 25th, 2003 10:27 PM |
