Modicon JSR Error
(8{)} ( .)
Apr 2004
Israel
625
Hi All,
I'm stumped.
I've a couple of subroutines in a Modicon controller (Quantum, 984LL). I debugged the subroutine and started writing a second routine for a similar task. When I went on-line I noticed that the 1st routine was running but the 2nd routine was labeled "SKIPPED".
On further investigation I noticed that the bottom leg (Subroutine Error) of the JSR block was on. I thought that there might be a problem with the code so I changed the reference to the working routine. Same results.
I searched a bit and couldn't find anything on what causes the bottom leg of the JSR to pass power.
Any ideas?
Thanks,
(8{)} ( .)
(Yosi)
Hello, I am rewriting some code and would like to start using JSR instructions for functions I perform regularly (zeroing out entries on the HMI...
3,747
Hello All, Was hoping I could get a little help with Modicon ladder logic. This is the first time I have seen Modicon logic and currently trying...
257
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
212
After updating a panel, I inherited another PLC for my "learning lab". It's a Modicon TSX Micro. I've not worked with a Modicon PLC yet, so I...
132
