ckchew666 Member Join Date Aug 2003 Location Malaysia Posts 591 Mar 3, 2006 #1 Hi, We've a customer which has a PV600, where by his arrows key (up,down,left, right) is malfunction. Is there anywhere we can write a program in PLC (SLC 500) to act as the arrows key? Thanks in advance.
jstolaruk Lifetime Supporting Member J Join Date Dec 2004 Location Detroit, SE Michigan Posts 3,907 Mar 3, 2006 #2 Those arrow keys are important for using the built in passowrd entry so I don't think so. If it is possible, wouldn't the cost of paying a programmer to recreate it in logic be more expensive than replacing the terminal?
ckchew666 Member OP Join Date Aug 2003 Location Malaysia Posts 591 Mar 3, 2006 #3 HI, Thc for ur comment. You are correct also, so best solution is to get a new PV and send the current one to repair.
