Siemens Laser Scanner LS4-4 AS-i Version
pboll
Nov 2005
Beijing
Hi everyone,
I'm using Siemens LS4-4 PLS which is AS-i Version, it's working, but the problem I have is I cannot get the warning signal.
I can see the amber light came on when there is object in the warning field. Occurding to the manuals, the output of the warning signal is thru AS-i. I'm using CP343-2P as AS-i master, but I cannot get any othing other than e-stop (cut-off the flashing signal).
So what I'm thinking is maybe I need to setup AS-i for the PLS. But how?
Is there anybody have some experience using this one?
Im not much help
I have used AS-I one time before but with different hardware. I had a Profibus AS-I master, e-stop, safety gate, etc. Each safety condition (e-stop, safety gate) has to have a safety output. The only way I could get the status of each condition was to assign a non-save output to the condition then bring that into a input on my plc.
I am not much help but there are a few more people on the board that have used AS-I and may have better ideas.
36
99
Hi need help why this “failure 5 emergency stop “ appears at every startup in the morning ? Have to shut off main switch at least 10 times on...
19
281
97
Hi everyone hope you'll well. Is it possible for me to download a Crack version of tia portal v13..sorry to say this but the software is very...
195
