This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Apr 2006
color animation of an object
Hi, My second day as a member and already a second question. I Hope I’ll be able to help someone someday… Here’s the (multi)question: (again, I’m working on RSView Studio 4 (CPR7)) I’m trying to animate the color of an object(polygon) with this expression: If ({tag1} == 0) Then 0 Else If ({tag1} == 1) Then 1 Else 2 tag1 is digital 1rst: what is the meaning of the {}? 2nd: When simulating, I receive this error: Expression contains a tag that has an error value After looking in the RA: KnowledgeBase, I’ve founded this post: http://domino.automation.rockwell.com/applications/kb/RAKB.nsf/0/278665D22EA125B485256ECA006A86F4?OpenDocument I don’t understand this answer, why creating a folder? If I understand correctly, I’m comparing an integer with a bit and that’s not possible but I’ve tried to change the type and data type of tag1 to Analog and Integer, but the same error appeared. 3rd: would it be possible to use this expression, (I’ve tried but got the same error msg): If {tag1}Then 1 Else 0 Meanings (for me as I understand it…): if tag1 is true then 1 many thanks(!!!)
__________________
FMorin |
#2 |
Being that this is a digital tag, just select the tag in the "expression" textbox don't add any other "logic" - just the tag, then select the color you want for the on state and the off state below.
Your "expression" has a minimum of three states 0, 1, and not 0 or 1. That is not possible with a digital tag.... See attached:
__________________
SSC Automation Last edited by 93lt1; April 6th, 2006 at 11:54 AM. |
#3 |
thank you 93lt1, you put back some pieces of the puzzle...
and guess what? it works
__________________
FMorin |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Calendar object in RSView SE display. | briana banks | LIVE PLC Questions And Answers | 0 | March 24th, 2006 07:01 AM |
| How to link recipe object to a string tag? | briana banks | LIVE PLC Questions And Answers | 3 | December 23rd, 2005 06:42 PM |
| Setting up CP 343-1 card (siemens) | Johnny T | LIVE PLC Questions And Answers | 35 | August 19th, 2005 06:58 AM |
| Cimplicity Class and Object | teh | LIVE PLC Questions And Answers | 0 | August 19th, 2005 04:12 AM |
| RSView Studio ME Trend Object Question | jstolaruk | LIVE PLC Questions And Answers | 3 | February 25th, 2005 05:46 AM |
