plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 19th, 2006, 02:43 PM   #1
BoSChoW
Slovenia
BoSChoW is offline
Simatic Op7 Error
Hey all , i finished an display program in ProTool and after i downloaded it to the OP7 an error appeared that it states:
$551 AS address 2 not possible. Does anyone know what does this mean?
All help will be aprishiated. Thanks again.
Old April 19th, 2006, 11:57 PM   #2
huynt
Viet Nam
huynt is offline
huynt's Avatar
Baudrate you set is 12Mb/s?. You use Op7DP or Op7 DP12?.
Can problem with baudrate if you use OP7/DP
__________________
Old April 20th, 2006, 05:24 AM   #3
Amr Hassan
Egypt
Amr Hassan is offline
this mean u have commuication problem with the plc
check cable , addresses , baud rate, ...
Old April 20th, 2006, 05:40 AM   #4
huynt
Viet Nam
huynt is offline
huynt's Avatar
How many OP you connect with one PLC,And What type of PLC do you use?.
__________________
Old April 21st, 2006, 06:54 PM   #5
RRobbins
United States
RRobbins is offline
RRobbins's Avatar
It means that there is no communication to address #2. Are you connecting the OP to the PLC with a profibus cable or a MPI cable into the PLC port on the display and not the serial port. I am assuming you configured the OP as a S7 device and not a S5.
Old April 22nd, 2006, 10:35 AM   #6
BoSChoW
Slovenia
BoSChoW is offline
How do i clear the data that i had transfered to the OP7 ??
Old April 22nd, 2006, 11:38 AM   #7
STL???
United Kingdom
STL??? is offline
From memory, you press ESC + Right Arrow + Down Arrow at the same time at Start up(Power up) of the panel. I think this wipes the unit and places it into transfer mode.
Hope this helps!
Old April 23rd, 2006, 02:34 PM   #8
BoSChoW
Slovenia
BoSChoW is offline
Yes it works, thank you man. Unfortunaly, i have an another question. I have a screen that looks like this:
Input01: 0
Input02: 0
Input03: 0
Input04: 0
I want to transfer the state of the input to the plc, any ideas how do i do this. I already tryed with selecting a function botton to do a transfer from OP to PLC but it said transfer locked, then i inserted an recipe and now is saing task invalid. What should i do?
Old April 23rd, 2006, 05:02 PM   #9
STL???
United Kingdom
STL??? is offline
Are you using a PLC JOB for your Data transfer? i had a similar message when using Job 51(force screen) because i wasnt sending the job number in Hex.
Please provide more detail or even post your program.
Old April 23rd, 2006, 05:12 PM   #10
BoSChoW
Slovenia
BoSChoW is offline
I defined in the protool that the F2 function botton will transfer the data from the op to the PLC, do i have to write a program in the function block to make the transfer possible?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Simatic S7 DLL error Werner LIVE PLC Questions And Answers 1 September 28th, 2005 02:21 PM
Siemens Simatic OP7 Error message wwlederer LIVE PLC Questions And Answers 2 September 17th, 2005 02:59 PM
Setting up CP 343-1 card (siemens) Johnny T LIVE PLC Questions And Answers 35 August 19th, 2005 06:58 AM
Simatic I/O Error 16# 494D No relevance for user (Z1): 0000 metaller LIVE PLC Questions And Answers 2 July 25th, 2005 02:10 AM
Siemens OP7 Protocol Error jeepslug LIVE PLC Questions And Answers 4 January 18th, 2005 11:00 AM
