plc storereviewsdownloads
Get the book!
If you're really looking to learn about PLCs, you NEED our book...
"Your Personal PLC Tutor - A Guide to Understanding PLCs"
Easy to read and uses 'plain' language!
Get $$FREE$$ priority mail shipping too!!!
You WILL be glad you did!!
Click Here now to order
Reply
Thread Tools Display Modes
Old April 21st, 2006, 06:04 PM   #1
Terry Woods
United States
Terry Woods is offline
FLIP-FLOP or FLIPFLOP or FLIP FLOP or TOGGLE or ONE BUTTON or ONE-BUTTON
This will work in ANY PLC. It is the "generic" solution for any PLC. It's only four Rungs in length and is totally transparent, to ANY PLC user, even Bubba! (OSR's can be confusing to some.)
The Flipping (Toggling) action takes place in only one scan.
This Rung watches for the PB to be pressed. When the PB transitions from NOT Pressed (OFF) to Pressed (ON), "FLIP-BIT" goes ON to flip the "TARGET BIT". "FLIP BIT" goes ON for no more time than it takes to scan the next two Rungs. And possibly, for as little time as it takes to scan the next one Rung.
SET-ting "WAS PB" prevents "FLIP BIT" from being re-activated, in subsequent scans, while the PB is still being pressed.
WAS
PB PB
---| |-------|/|---+---( ) FLIP-BIT
+---(SET) WAS PB
If the PB is just-now pressed, and the "TARGET BIT" is ON, then "TARGET BIT" is RESET (Turned OFF). Then, the driving signal, "FLIP BIT", is RESET (Turned OFF). If "FLIP BIT" is turned OFF in this Rung, then the next Rung is prevented from operating on the "TARGET BIT".
FLIP TARGET
BIT BIT
---| |-------| |---+---(RST) TARGET BIT
+---(RST) FLIP-BIT
If the PB is just-now pressed, and "FLIP BIT" is still ON (not RESET in the previous Rung), and "TARGET BIT" is OFF, then "TARGET BIT" is SET (Turned ON). Then, the driving signal, "FLIP BIT", is RESET (Turned OFF). Since "WAS PB" was SET (Turned ON), Rung-1 is prevented from being activated.
FLIP TARGET
BIT BIT
---| |-------|/|---+---(SET) FLIP-BIT
+---(RST) FLIP-BIT
When the signal from PB finally goes OFF, after having been ON ("WAS PB" is ON), then run that pair of conditions through a short-termed Timer (1-second). After timeout, RESET (Turn OFF) "WAS PB". That produces a "debouncing" effect. When "WAS PB" goes OFF, the first Rung is allowed to "watch" for the next pressing of PB.
WAS
PB PB +---------+
---|/|-------| |----+ TIMER +---(RST) WAS PB
| 1-Sec |
Old April 21st, 2006, 08:40 PM   #2
Rube
United States
Rube is offline
Rube's Avatar
Quote:
"even Bubba!"
Hey, I resemble that remark!
I guess Terry has settled the background noise for a month!?
__________________
Mark A. Crowley
Automation is not a corrective action for a lack of discipline.
Old April 22nd, 2006, 12:48 AM   #3
rsdoran
United States
rsdoran is offline
rsdoran's Avatar
4 rungs for a flip flop?
Personally I disagree with the use of the term flip flop.
In many cases the descripton of one input used to alternatte an output is called a JK flip flop...that is just wrong.
One rung with many branches is not innovative..especially when talking about an S7-200...it has a "toggle" instruction.
I posted examples of "toggle" or flip flop with Terry's flowchart to help.
Flip flop's are electronic devices used for a specific purpose, a PLC can simulate it BUT it is not one...it can do more.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand."
Old April 22nd, 2006, 08:23 AM   #4
TSmith
United States
TSmith is offline
This AB logic. It is a simple toggle
!st time input is true CTU=1 Output is on
2nd time input is true CTU=2,resets,CTU=0 Output is off
Is there an easier way to post pics or drawings? Thanks
Old April 22nd, 2006, 09:09 AM   #5
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Our you can do it like this,
You can call it...JK-Flip-Flop, RS-Flip-Flop, JFK-Flip-Flop
What ever you want, as long as your output is true when you want it to be.
PS. Tsmith... my neck hurts
edit: I cant seem to get the pic to insert??, but here is a PDF
Edit: Got it...you must read, hmmm
__________________
www.PLCTrainer.net
PLC Trainers, Communication Cables and Automation Supplies, ((NEW)) Siemens S7 1200 trainers
Old April 22nd, 2006, 11:00 AM   #6
Terry Woods
United States
"I guess Terry has settled the background noise for a month!?"
Apparently not.
Yes Ron, there are indeed four rungs.
Ron... A rose by any other name is still a rose.
I just used what seemed to be the most common names for the sake of searching.
The point of my post was to present a "flip-flop-toggle-whatever-thingee" that would work in ANY PLC. The only element that might be considered exotic is the timer. However, even Smart Blocks (Smart Relays) have timers.
I've always been bothered by brand-specific solutions. A solution created for a particular brand of PLC might be so unique that it can't be applied to other PLCs. This code will apply to any PLC. Any programmer can read it and understand it. The concept is apparent. Having understood the concept... any programmer can then use those unique tools in his particular tool-box to realize the concept in any manner he wishes... or, with only one caveat, he can use the code exactly as I have presented it. The caveat is in regards to the timer. It appears that most PLCs handle timers differently. So, apply the timer in the manner required for your particular PLC.
"One rung with many branches is not innovative..especially when talking about an S7-200...it has a "toggle" instruction."
One rung?
I thought we just agreed that it was four rungs.
S7-200?
I thought I made it clear that this code is for use in ANY PLC.
So Ron... what's your point?
(From "Never-Never-Land"... where believing in yourself can produce some pretty amazing results!)
Old April 22nd, 2006, 01:02 PM   #7
Jim Dungar
United States
Jim Dungar is offline
Terry,
Look at your third rung. The logic does do not match with the description.
Shouldn't it be |---+---(SET) TARGET-BIT ?
Old April 22nd, 2006, 03:28 PM   #8
Terry Woods
United States
The best laid plans of mice and men...
Damn it Jim! You are so right.
WAS
PB PB
+---(SET) WAS PB
FLIP TARGET
BIT BIT
+---(RST) FLIP-BIT
FLIP TARGET
BIT BIT
---| |-------|/|---+---(SET) TARGET BIT
+---(RST) FLIP-BIT
When the signal from PB finally goes OFF, after having been ON ("WAS PB" is ON), then run that pair of conditions through a short-termed Timer (1-Second). After timeout, RESET (Turn OFF) "WAS PB". That produces a "debouncing" effect. When "WAS PB" goes OFF, the first Rung is allowed to "watch" for the next pressing of PB.
WAS
PB PB +---------+
| 1-Sec |
Old April 22nd, 2006, 04:39 PM   #9
Jim Dungar
United States
I Like my MGD room temp and served in a frozen mug.
Old April 22nd, 2006, 05:41 PM   #10
Terry Woods
United States
Jim,
Do you try to develop a large head? Or do you pour it down the side?
I go for no head!
Old April 22nd, 2006, 06:47 PM   #11
Archie
United States
Archie is offline
Archie's Avatar
An even more universal solution. No Set/Resets. No Latch/Unlatch. No Counters. No Timers. No Time delay to deal with.
PB Target R1
R1 | PB |
PB R1 Target
Target| PB |
1) Target and R1 starts out both off
2) PB is pressed and held. Only R1 is on
3) PB is released. Both R1 and Target are on
4) PB is pressed and held. R1 drops out
5) Button is released. Both R1 and Target are off as in step 1
Last edited by Archie; April 22nd, 2006 at 06:49 PM. Reason: Ladder was showing wrong
Old April 22nd, 2006, 06:57 PM   #12
Gerry
New Zealand
Gerry is offline
How about this for generic.
Some very basic / stone-age PLC's don't support multiple outputs on a rung. And even those have input filtering, so a debounce is redundant (unless the operator has Parkinson's).
Still 4 rungs though
PB aux OS
PB aux
OS TOGGLE TOGGLE
----] [-------]/[-----------------(L)--
OS TOGGLE TOGGLE
----] [-------] [-----------------(U)--
Slightly less generic using output branching:
Down to 2 rungs. (This one's better if I/O is asynchronous)
PB aux OS
| aux
OS TOGGLE TOGGLE
----] [---+---]/[-----------------(L)--
| TOGGLE TOGGLE
+---] [-----------------(U)--
Last edited by Gerry; April 22nd, 2006 at 06:59 PM. Reason: Archie types faster (no change)
Old April 22nd, 2006, 09:19 PM   #13
TSmith
United States
TSmith is offline
I agree with the concept of less rungs is better. I do not have the experience of the major posters here, but I learned early on, you can get so fancy that it does't work.
Old April 23rd, 2006, 08:15 AM   #14
Jim Dungar
United States
Tsmith said "you can get so fancy that it does't work" - well put.
Terry, If the brewmaster had intended the beer to be flat, he wouldn't have put in the bubbles in the first place.
Old April 23rd, 2006, 09:10 AM   #15
Terry Woods
United States
Archie,
Yours will work, however, isn't it kinda weird to operate a light or motor by "releasing" a push-button? And it is not exactly what I would call easy to decipher. Bubba would probably get dizzy trying to figure it out.
And by the way Archie, the conditions that cause the need for "debouncing" should not be considered frivolous.
Gerry,
Neither of yours will ever work in the vast majority of PLCs. If the light is ON you can turn it OFF.. however, the problem is that the light can never be turned ON!
Gerry said...
"Some very basic / stone-age PLC's don't support multiple outputs on a rung. And even those have input filtering, so a debounce is redundant (unless the operator has Parkinson's)."
Gerry, if you were hired to create a One-Button Toggle-Function that would work in ANY PLC, would your statement have any validity at all? Notice that the key-word is "ANY"... that would include all of those "...very basic / stone-age PLC's...". Even those that don't have built-in filtering!
Jim...
Since I paid for those bubbles... I prefer to keep them for myself rather than letting them bubble away into the atmosphere!
If ya can't get a good healthy buuuurrrrp.... out of them bubbles, then what the hell is the point of havin' 'em?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Flip Flop and Something to think about rta53 LIVE PLC Questions And Answers 13 April 24th, 2006 08:16 AM
Question for S7 Guy or another XOR flip flop expert! 504bloke LIVE PLC Questions And Answers 2 March 15th, 2006 07:26 AM
flip flop logic Unregistered LIVE PLC Questions And Answers 12 May 1st, 2005 08:59 PM
Flip flop or toggle: a rehash rsdoran LIVE PLC Questions And Answers 8 January 29th, 2003 02:58 PM
