plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 24th, 2006, 01:17 PM   #1
BigJohnT
United States
BigJohnT is offline
Change Counter Acc in Code RsLogix
Can you change the value of a counter Acc in code with RsLogix on a 1500 micro?
I have some sequence logic that uses a counter to control the sequence. In some cases I need to back up the counter.
John
Old April 24th, 2006, 01:34 PM   #2
jstolaruk
United States
jstolaruk is offline
John
yes, a move instruction will work. MOV n7:0 c5:0.acc
Also SUB, ADD, DIV, or MUL.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old April 24th, 2006, 01:38 PM   #3
BigJohnT
United States
BigJohnT is offline
Thanks, I did not even think about the math instructions (slapping forhead)
John
Old April 24th, 2006, 01:45 PM   #4
jstolaruk
United States
John
I belive the CPU will fault if the counter/timer accumulator gets a negative number in it though. Some range checking would not be a bad idea.
__________________
Old April 24th, 2006, 01:48 PM   #5
BigJohnT
United States
BigJohnT is offline
That's for sure something like -32647 to 32648 or some number like that will fault the cpu.
THanks
John
Old April 24th, 2006, 02:22 PM   #6
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
The PLC will fault on negative numbers for timers. However counters do just fine with negative numbers in the PRE and ACC.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSLogix 500 PLC sample code for 4-Loop PID blend controller welday007 LIVE PLC Questions And Answers 2 December 22nd, 2008 01:22 PM
RSLogix 5000 V15 Features Samneggs LIVE PLC Questions And Answers 18 April 20th, 2006 05:45 PM
RSLogix 5000 Footage Counter Program Scotnet LIVE PLC Questions And Answers 0 March 1st, 2005 06:59 PM
Simulator, Simulation, Shadow Code Terry Woods LIVE PLC Questions And Answers 1 January 2nd, 2005 01:40 PM
Mapping RSLogix Code Aaron LIVE PLC Questions And Answers 3 March 19th, 2003 12:04 PM
