This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Apr 2006
RSView ME AOA Initialize Failed
I have a new copy of RSView ME and when ever I try to open the tag database, I get the following error:
"AOA: AOAInitialize failed" I have called tech support, no help, Uninstalled and reinstalled, no help, checked tech notes on-line, no help. Has anybody seen this and solved the problem. Thanks much, Mollyputzer |
#2 |
What version of RSView? Studio or Runtime?
Did you actually try anything from the technotes? Especially: http://domino.automation.rockwell.co...A?OpenDocument More: http://domino.automation.rockwell.co...0?OpenDocument http://domino.automation.rockwell.co...4?OpenDocument http://domino.automation.rockwell.co...3?OpenDocument http://domino.automation.rockwell.co...1?OpenDocument |
#3 |
I had the same problem with ME until I applied the patches from Rockwell's website.
#4 |
rdrast,
The bottom tech note about decompressing the hard drive is the one that I did not find on their website, but it is the one that worked. Thanks much for your help |
#5 | |
Quote:
Edit: I have version RSView Studio ME 4.00.00 (CPR 7)
__________________
"If there is a problem, there is a solution. If there is no solution, then there is no problem." - unknown ![]() Daniel Camacho Last edited by DanielCamacho; March 6th, 2007 at 09:59 PM. Reason: More info... |
#6 |
I have almost always recovered from this error by using the Application Manager to backup the application (create the .apa file) and then restoring the application with a new name.
I've seen this error many times and this has almost always fixed it. OG |
#7 | |
Quote:
__________________
"If there is a problem, there is a solution. If there is no solution, then there is no problem." - unknown ![]() Daniel Camacho |
#8 | |
Quote:
__________________
#9 |
![]() Join Date: Jul 2006
Error "AOA: AOAInitialize failed" when trying to open tag database in RSView Studio application.
Answer Problem : Error "AOA: AOA Initialize failed" when trying to open tag database It is possible that tag database is corrupted , but deleting RDMDATA folder and rebooting PC did not help RSView Studio works fine with another application on the same PC. Workaround : Start a new application -select IMPORT select RSView Studio med file , and navigate to the problem project, select med file , finish . The project is recreated and database is OK Problem: Error "AOA: AOAInitialize failed" when trying to open tag database |
#10 | |
Quote:
__________________
#11 |
![]() Join Date: Nov 2007
RSView ME AOA
I found the following in the Rockwell Knowledge Base that has worked for every machine that I have had this problem on (Mostly HP machines running Windows XP). Search for E56958998 on the Rockwell website http://www.rockwellautomation.com/knowledgebase/
I hope this helps anyone having this problem. Richard |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Vintage AB Product Conversion to RSView ME | Danocane | LIVE PLC Questions And Answers | 3 | March 5th, 2006 12:16 AM |
| RSView SE to SQL DB | Hardwerk | LIVE PLC Questions And Answers | 11 | November 17th, 2005 04:48 PM |
| Using functions in a Custom DLL in RSView | ettikudiappan | LIVE PLC Questions And Answers | 1 | September 23rd, 2005 06:47 AM |
| Siemens S7 400 with RSView | inisys | LIVE PLC Questions And Answers | 1 | December 13th, 2004 09:45 AM |
| RSView Studio to RSView 32 Works | ladderlogix | LIVE PLC Questions And Answers | 0 | June 9th, 2004 07:26 PM |
