plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 19th, 2006, 05:47 PM   #1
pdelno
United States
pdelno is offline
electromagnets
i was woundering if any body here has used electromagnets in any projects.
i have a idea about using some for a project and can't really find any of the info i need.
if anybody has info on them. like controling them and manipulating the force of the magnets. I know this is off the plc topic but it might get there.
Old May 19th, 2006, 06:14 PM   #2
Archie
United States
Archie is offline
I worked with a machine that used small ones. A disc brake pad would slide onto the magnets, they would energize, then the arm would turn the pad upside down over a conveyor. The magnets would de-energize to drop the pad on the conveyor.
It was a very simple on/off application with 24VDC magnets.
Old May 19th, 2006, 06:47 PM   #3
dalem
United States
dalem is offline
I've used the following peoples magnets. http://www.magnetics.com/I've also ordered elect magnets out of McMaster Carr. Probably a cheaper route for experimenting.
Old May 19th, 2006, 07:14 PM   #4
keithkyll
United States
keithkyll is offline
Some info about them here, including a schematic:
http://www.plctalk.net/qanda/showthr...=electromagnet
Old May 19th, 2006, 08:51 PM   #5
jstolaruk
United States
jstolaruk is offline
Have used them a few times but they also attract metal shavings and grinding dust that don't want to fall off when the magnets are deenergized (residual) so they end up being a maintenance issue. Generally we stay away from them.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old May 19th, 2006, 09:17 PM   #6
pdelno
United States
pdelno is offline
thanks guys
dalem that was what i was looking for
i think they may have what i want
Old May 19th, 2006, 09:23 PM   #7
pdelno
United States
pdelno is offline
jstolaruk we weld blanks togeather with lasers so fairly clean. right now there are suction cups the crowd the 2 blanks togeather. there is a lot of oil on the parts which gets into the vac system and causes a lot of problems. there fix right now is to sandblast the cups but that messes up the sealing surface. i was thinks of using small magnets the replace the suction cups.
thanks agian guys
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
