plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 22nd, 2006, 05:02 AM   #1
srik
India
srik is offline
srik's Avatar
Sequence of event recorder
I want some information regarding Sequence of event recorder in DCS/PLC. Is it required to add some special module for sequence of event recording? Or Process controller it self is sufficient to perform this function? I worked with ABB DCS .I have not found any special module there. Is there any deference between DCS and PLCs to use this function?
Old May 22nd, 2006, 06:11 AM   #2
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
Typically something like this is done with a historian that is not part of the control system, but is connected to it. Most DCS systems have a historian option, as do most SCADA systems. By historizing discrete and analog control values, you can go back in time and see what was happening at any given moment.
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity."
- Donald A. Adams
Old May 22nd, 2006, 07:19 AM   #3
srik
India
srik is offline
srik's Avatar
Thanks to search_automation and Ken Moore
Is the module need hard wiring?
I am now searching for SOE modules of Rockwell and ABB.
Thanks once again
Old May 22nd, 2006, 07:30 AM   #4
mgvol
United States
mgvol is offline
mgvol's Avatar
Below are SOE modules that Rockwell offers for the Contrologix platform:
Input modules
1756-IB16ISOE (24-48 vdc)
1756-IH16ISOE (125 vdc)
GPS Time Input modules
1756-HP-GPS
The Input modules can provide microsecond time-stamping.
Old May 22nd, 2006, 11:55 PM   #5
srik
India
srik is offline
srik's Avatar
Is it possible to use anlalog signal for these SOE special modules ?
1756-IB16ISOE (24-48 vdc)ABB module is useful for digital inputs only.
Old May 23rd, 2006, 06:43 AM   #6
mgvol
United States
mgvol is offline
mgvol's Avatar
AB does not have any special SOE analog input modules, but a standard analog input, like the 1756-IF16, can be configured for high-speed CST (coordinated system time) time-stamped data.
Old May 24th, 2006, 11:29 AM   #7
ldevar1
United States
ldevar1 is offline
hai
hai
Old May 24th, 2006, 11:35 AM   #8
ldevar1
United States
ldevar1 is offline
substation automation
Hai,
I am new to this form. I am working on a project for substaion automation. We r using SLC 500 to connect the alaram of 8 individual substaions to a master SCADA substation. The SCADA master needs to pull out sequence of events for each subs. I am not sure id SLC 500 can do any of the fillowing functions-
-Trasient fault analsysis.
-Disturbance recorder.
-Power quality monitor.
-Fault locator-to calculte the distance of fault
-Realtime monitor.
-On-line switchgear monitor.
Do I need seperate modules tp performa the above functions. I have searched AB site for this info, but did not finf any. can anybody help?
Old May 24th, 2006, 12:01 PM   #9
mgvol
United States
mgvol is offline
mgvol's Avatar
You will need to go with the ControLogix platform; there are no SOE modules or time-stamping capability with the SLC. I do know that a GPS module (typically used for SOE time-stamping) has been released for the CompactLogix platform, but I'm not aware of any hi-speed SOE input modules.
Old May 24th, 2006, 12:06 PM   #10
Sheldn
United States
Sheldn is offline
Sheldn's Avatar
If you are looking for sequence recorders that can do sub-cycle (60Hz/50Hz) you need to look at manufacturers that make this type of product such as Dranitz for power (transient, power quality, fault sequence) or Bently-Nevada for Vibration.
AB and Modicon have products for substations that can do this type of SOE and will need to get the data up to your historian from the module. I am not certain what the response time rating of the individual I/O points are, however, you should check to be sure your application needs are met. If you want to try to have your standard historian software with OPC communication links to talk to a PLC to get data from an I/O point every 1-10 msec, then I wish you luck.
__________________
Old December 21st, 2010, 01:52 AM   #11
BUJJI
India
BUJJI is offline
Soe
I am new to this form. I am working on AUTOMATION systems. We r using MAXIFLEX SEQUENCE EVENT RECORDER to connect the alaram of 8 individual substaions to a master SCADA substation. The SCADA master needs to pull out sequence of events for each subs. I am not sure that what it can do, please give the various parameters that it can reacord as events, with application as example.
Plz give me awareness on this on which parameters we can work with this and how we can give the alaram annunciator to the scada system.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
sequence of event recorder srik LIVE PLC Questions And Answers 2 May 22nd, 2006 03:00 AM
Sequence of event in RSView32 Deer LIVE PLC Questions And Answers 3 May 15th, 2006 11:27 AM
G-Code Jim Dungar LIVE PLC Questions And Answers 19 March 18th, 2005 09:44 PM
Periodic event & Event in RSView ckchew666 LIVE PLC Questions And Answers 1 October 8th, 2004 07:37 AM
S7-416-2 DP Fault - SFB20 sparky64 LIVE PLC Questions And Answers 8 July 30th, 2004 02:48 AM
