This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Hi All,
Thanks for the great help... here I go again... I need to monitor the power supply voltage going into sliprings, basically from a 24v power supply. But I want to monitor this via a momentum PLC. Basically something similar to a multimeter with outputs. Only I just need the voltage only. Basically the system suffers power dips now and again. When the slip rings (copper based) are getting dirty, I just need to monitor when the supply voltage begins to drop indicating that the slip rings are getting dirty and then get them cleaned. Help will be greatly appreciated. I tried looking around this site for a similar problem, but it looks like I am out of luck. Thanks, |
#2 |
I have seen battery voltage in remote panel SCADA systems monitored by using a voltage divider (2 resistors) sized so that 24V would be ~5V into an analog card. A voltage input should have a high enough impedance that it's current draw can be neglected in the votage divider equation, but you can check to be sure by looking at the specs for the card.
#3 |
![]() Join Date: Jul 2004
If your looking for a specific value of voltage, say 22.2V, then get a converter that can take your 0-25V and turn it into your analog input. If your looking for if it drops below 19.9V I have used voltage relays, that I set the drop out voltage and it becomes a digital input to the PLC.
George |
#4 |
Have a look here: Model SIX
http://www.miinet.com/products/sg_signal.shtml
__________________
Mickey If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else. ----- Chinese Proverb |
#5 |
![]() Join Date: May 2006
I used a 1500 ohm resistor on an analog input to get 0-30 volts.
scaled 0-20 ma. |
#6 |
thanks guys... had a look around and found that a transducer could do what i am asking for. but for the price, it is not worth it.
what i am simply needing now is a contact that will go on when a voltage larger that 24V DC passes through, and go off when the voltage drops below 20V DC, this can be a digital input signal to my momentun PLC. a fancy proximity switch if you ask me.Is there a product like this out there? cheaper than a transducer off course. |
#7 |
![]() Join Date: Aug 2005
Take a 24v relay and put a 10K pot on the + side. Turn the pot down till the relay drops out then up till it comes on.
Just an idea. |
#8 |
#9 |
this is it... thanks a lot!
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Ground/neutral | alanc5 | LIVE PLC Questions And Answers | 31 | October 14th, 2006 04:54 PM |
| Supply voltage undersized | johnnysparks24 | LIVE PLC Questions And Answers | 24 | January 9th, 2006 10:38 PM |
| Best way to upgrade a SCADA system | Johnny T | LIVE PLC Questions And Answers | 10 | May 3rd, 2005 03:38 AM |
| grounding | lab | LIVE PLC Questions And Answers | 30 | December 31st, 2004 02:05 AM |
| SLC 5/03 and low voltage supply | Ken Moore | LIVE PLC Questions And Answers | 3 | June 26th, 2004 09:05 AM |
