This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Nov 2005
Intouch Wonderware,Top Server, Siemens s7-222
Hi all,
Can any one elinghten me as to how to have these three packages (Intouch Wonderware,Top Server, Siemens s7-222) work togehter. My control program runs on the siemens s7-222, I am planning to create the HMI in wonderware and Top server will be the server used. I am looking for a layman explaination, and possibly some user friendly documentation/ website on the subject area to help out. Regards Black Slipper |
#2 |
You will use TopServer, with the unified Siemens S5/S7 Suite driver to create an OPC link between Wonderware and the PLC. Depending on the version of Wonderware, you may also need to run on the PC the Wonderware OPC client (one of their servers).
Topserver is what translates the WonderWare tag reads and writes into something the PLC can understand, as well as the reverse function. |
#3 |
So does the top server interact directly with my field instruments and them use the whoderware HMI as a display for example
#4 |
No, as you stated, TopServer is the OPC Driver for the PLC. It will interact with the PLC's data (provided you select the proper addresses to read/write).
If you have field instruments connected to the PLC, then you can read the state of them from the PLC, not the instrument directly. If you have additional drivers in TopServer, for the instruments, then you can read/write them directly from WW. |
#5 |
rdrast
What does WW mean. I am gonna try today in the lab to see if I can make the Server acquire data directly from the PLC as stated. Thanks |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Siemens S5 and S7 Dual Masters for Profibus | daveswerld | LIVE PLC Questions And Answers | 15 | December 16th, 2008 02:15 AM |
| Siemens S7 Ethernet Problem | S7Guy | LIVE PLC Questions And Answers | 7 | February 4th, 2008 02:51 PM |
| OPC Server for Siemens and Ethernet | Prince | LIVE PLC Questions And Answers | 8 | August 24th, 2004 06:52 AM |
| Siemens S7 ethernet protocol | fzhang | LIVE PLC Questions And Answers | 3 | May 19th, 2004 12:06 PM |
| AB panelView Plus MMI with Siemens S7 314 | iknowsomeplc | LIVE PLC Questions And Answers | 0 | November 18th, 2003 12:52 AM |
