This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
I have an idea to use plc in making the gears system in automabile electronically controlled.Can plc be used in this project.The basic theme is to give electric signal to change gears. Ur valuable suggestion are awaited. Thanks |
#2 |
You are a few years late: http://www.aa1car.com/library/2002/us90224.htm
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand." |
#3 |
Besides, shifting gears is such a waste of time... CVT's, or the planetary transmission used in the Prius are the way to go.
But, if you must, the answer is Yes. A PLC could generate the signals to control an electrically switched automatic transmission... So could a dedicated microcontroller, a few op-amps and some transistors, or, wow... an actual ECM (Engine Control Module) with the ability to handle a transmission. |
#4 | |
Quote:
Maybe I'm missing something, but why don't the hybrid developers just use servos at the wheels and couple the engine only to an alternator, skipping the mechanical drivetrain? |
#5 | |
Quote:
Is that what car is in your avatar? a Prius?, what kind of mileage do you get? have you seen the Prius's in Cal. they changed the batteries and are getting 100mpg +, I have a 62 mile commute but I was told that the hybrid was not for me...due to the fact that I only have 6 stops signs on my drive and that the real savings comes from regenerative breaking (I also been told) I'm waiting for the full electric...but also a reasonably priced one.
__________________
www.PLCTrainer.net PLC Trainers, Communication Cables and Automation Supplies, Allen Bradley ~ Siemens ... YouTube PLC help videos.. http://www.ind-concepts.com/Support_and_Downloads.htm |
#6 |
Yes, it is a Prius, and I've had zero problems with it in 60k miles so far.
My commute is about 100 miles a day, all highway, no traffic. If I drive, er, uhh... well, somewhat above the speed limit (say in the 80's, hypothetically), with A/C on, I get 40mpg. Slowing down to posted speeds, I go up to about 45. That is less than I originally got, but I switched to more comfortable (softer rubber) tires. With Low Rolling Resistance tires, I was in the 46 to 50mpg range usually. |
#7 |
How did it stop and handle with the Low Rolling Resistance tires?
#8 | |
Quote:
I changed out primarily because I needed a new set at 40k or so, and with limited time, had to get what was available at the local Bridgestone shop
#9 |
Put larger diameter tires on the rear axle.
That way you are usually going down hill and save fuel Rod |
#10 |
Well, that explains a lot.
I always wondered why my trike would always rolled backwards when I was a young tot. Now I know.
#11 | |
Quote:
#12 |
I think my next one will be a Jetta (diesel) it gets around mid40's the sticker price is little better then the Toyota, I got 140,000 on my Kia
, ya not the best looker, but no issues to date...besides the 140lb dear, I trade it in when I hit 200,000, I should get a good price {sarcastic}
__________________
#13 | |
Quote:
I have seen some nifty ford Rangers that had the gas motor replaced with an electric (actually a large diesel starter motor). The bed was full of batteries, but I think a small genset would be ideal. What kind of voltage does the Prius and others use? I know the fire dept's have had some special training as a result of the 120 volt headlights (AC) that some cars are using. regards all.....kc |
#14 |
Didn't the Edsel have an electronic, or electric push-button shift?
__________________
If you think you can do a thing or think you can't do a thing, you're probably right.... Henry Ford |
#15 |
![]() Join Date: Jul 2006
Most cars us microcontrolers on a CAN network to do stuff like this.
A project I work on can be seen at www.osuchallengex.com |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| It SOUNDS like a good idea.... | Tom Jenkins | LIVE PLC Questions And Answers | 11 | June 26th, 2006 09:52 PM |
| Slightly OT: Electronic roadsigns | Ken Roach | LIVE PLC Questions And Answers | 3 | May 3rd, 2006 10:32 AM |
| Connecting electronic VSDs (slightly OT) | Doug_Adam | LIVE PLC Questions And Answers | 4 | November 9th, 2003 06:28 PM |
| yeah/neh on idea for SLC housekeeping idea? | ganutenator | LIVE PLC Questions And Answers | 3 | May 23rd, 2003 01:35 PM |
| Idea: MICROMASTER | Combo | LIVE PLC Questions And Answers | 7 | August 28th, 2002 02:13 PM |
