plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 4th, 2006, 01:09 AM   #1
hotrod
United States
hotrod is offline
hotrod's Avatar
Siemens plc bits dropping out on start up.
The program seems to be ok, when we go online with the plc and watch the rungs, there are bits dropping out with no explaination, no ryme or reason why, there are five I/O's and 16 drives and a couple inverter drives. ac to dc inverters. In short this is all interfaced with a wire drawing machine built in Italy, custom drives ect. In short I'm getting an alarm for something that isn't true, any advice would be big help, thanks guys.
Old August 4th, 2006, 02:01 AM   #2
PeterW
Canada
PeterW is offline
without more info I can only guess, although as the machine comes from Italy, they wouldn't do this.
But a common problem with new users to Siemens is to forget that Siemens is BYTE orientated, that is it the flags are BYTES of 8 bits and to get a WORD they combine two BYTES.
Therefore Memory Word 2 is really a combination of Memory Byte 2 and Memory Byte 3. So if you use a program where you are using M 3.2 as a flag and in that same program you transfer an integer into MW2, then all MB3 bits will be overwritten.
As I say with no real info this is just a guess.
Old August 4th, 2006, 03:21 AM   #3
RMA
Scotland
RMA is offline
RMA's Avatar
If the problem is only on startup and once up and running, everything is OK, then two possibilities are:
1) There is some initialising being done in OB100 (or 101 or 102 if its a 400 CPU)
2) Some of the data has been declared non-retentive, so that the state is lost following a power down
To get any nearer to the answer, we need a bit more detailed info.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Communication on ethernet between AB PLC and Siemens PLC Chandrashekhar_basap LIVE PLC Questions And Answers 4 May 28th, 2006 04:03 PM
Wonderware 7.11 with Siemens S7 400 and Allan Bradley plc shandra_ck LIVE PLC Questions And Answers 3 September 5th, 2005 09:39 PM
Siemens S7-400 PLC communication Jing Zhi LIVE PLC Questions And Answers 2 September 1st, 2004 07:32 AM
Siemens S7-300 series PLC to PC communication Mahesh LIVE PLC Questions And Answers 1 December 7th, 2003 05:21 PM
S5 PLC Siemens Softnet V6 LSAP frobie LIVE PLC Questions And Answers 0 February 4th, 2003 11:19 AM
