plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 4th, 2006, 06:26 AM   #1
m_reavis
United States
m_reavis is offline
panelview plus 1000
Hi, I am working a panelview plus 1000 for a conveyor company and I would like to replace the AB screen saver bitmap with the company logo bitmap. Is this possible, if so does anyone have any ideas?
__________________
m_reavis2001@yahoo.com
Old September 4th, 2006, 06:39 AM   #2
rPraveenkum
India
rPraveenkum is offline
rPraveenkum's Avatar
Yes possible!!! you have to define in the Terminal Configuration
Old September 4th, 2006, 06:47 AM   #3
m_reavis
United States
m_reavis is offline
unclear
I assume you are talking about the terminal setup screen. I find the screensaver utility but do not see a way to change the bitmap. only turn it on or off and intensity settings.
__________________
Old September 4th, 2006, 06:57 AM   #4
rPraveenkum
India
see this
http://domino.automation.rockwell.co...256E7F006F61B8
Old September 4th, 2006, 07:25 AM   #5
m_reavis
United States
m_reavis is offline
thanks
Thanks for the information. I tried to search for that in the knowledge base but have a hard time narrowing the search to a manageable number of hits.
Again, thanks a lot!!
__________________
Old September 4th, 2006, 11:23 AM   #6
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
Quote:
Originally Posted by rPraveenkum
There are no manageable hits. This is a direct link to an article on the Rockwell Knowledgebase. This article details exactly how to change the screensaver bitmap.
OG
Old September 5th, 2006, 04:14 AM   #7
m_reavis
United States
m_reavis is offline
da
ya I got that, I meant the search I did of the ab knowledge base before I posted the question. Anyway the instructions are clear except when they refer to Storage Card2 I assume they mean any storage device including usb flash drives. Also I program with windows 2000 professional the OS for the screen is CE will this be a problem?
__________________
Old September 5th, 2006, 07:42 AM   #8
rPraveenkum
India
Quote:
refers the compact flash drive
Old September 5th, 2006, 07:57 AM   #9
baref00t25
United States
baref00t25 is offline
One easy way to modify the screen saver is to connect an USB keyboard to the panelview plus. Press, Ctrl + Alt + Shift + Windows_Start_Key at the same time. This will bring up a sort of task manger. Type in control.exe You have to do most of the file management using the browse window, but it works great.
Old September 5th, 2006, 08:01 AM   #10
rPraveenkum
India
Quote:
gooooooood information
Old September 9th, 2006, 10:32 AM   #11
m_reavis
United States
m_reavis is offline
thanks again...one more question
Hi, this is good information. I have an unrelated question about uploading a .mer file from a running touchscreen and converting it to an .apa file that can be restored for use in RSView Studio. To me this should be a no brainer, I hate to download a program that may or may not be a match for what is running.
__________________
Old September 10th, 2006, 03:51 PM   #12
jasdhillon
United States
jasdhillon is offline
jasdhillon's Avatar
I dont think it allows you to upload. I even tried to upload to the flash card, but the file did not work. You can back up the application that you creat.
__________________
Gypsy
Old September 11th, 2006, 12:19 AM   #13
Operaghost
United States
Operaghost's Avatar
The .mer file is not convertible to a .apa file. The idea is that developers can supply you with the runtime file (.mer) but they retain the source code (.apa) as "intellectual property".
This way I can't walk up to a system developed by a competitor and pull their project out of the terminal and modify it to fit my needs. They spend all the time and effort developing a function app and I slide in the back door and copy it.
So, to get the .apa you must have the original source code. Likewise if I develop a C++/VB app, I will provide the runtime to the customer but I won't give them my source code because I have time and money invested in that.
If you must have the source code, you need to have that specified in the contract or specification. You can ask for it afterwards, but you may not get it.
OG
Old September 11th, 2006, 06:37 AM   #14
baref00t25
United States
It is possible to convert a .mer file to a .apa file, but it isn't straigh forward. One must pull the .mer file off the Panelview Plus and then run it on their PC. Once run ont he PC it creates a directory with several files. From these files you can place them in RSView ME directory where applications are stored (over the top of an existing one) and the application will load in RSView ME for you to back it up to a .apa file. You will lose certain pieces of information like the alarm lists and global connections. It takes a little playing around with, but you can look through the alarm file and get a good idea of what the alarms were. The last time I had to do this type of conversion on a rather simple 20 screen HMI took me about 4 hours to rebuild.
Old September 12th, 2006, 04:52 AM   #15
m_reavis
United States
m_reavis is offline
convert .mer to .apa
does sound a bit involved, I'd like to give it a try but would hope for more detailed information for file locaction, which files and such. I wonder if ab has anything in knowledgebase? I'll give it a look but don't hold out much hope. Let the games begin.
Mark
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Modbus with SLC5/04 and PanelView 1000 Jimmie_Ohio LIVE PLC Questions And Answers 4 September 26th, 2005 08:37 AM
Panelview 1000 Security AGIESKE LIVE PLC Questions And Answers 2 April 16th, 2004 12:13 PM
Communication between PanelView 1000 and SLC 5/04 RP LIVE PLC Questions And Answers 50 December 9th, 2003 12:50 PM
Display String file on PanelView 1000 wa5yom LIVE PLC Questions And Answers 33 September 15th, 2003 10:53 AM
Compactflash for Panelview 1000 sreev LIVE PLC Questions And Answers 4 January 17th, 2003 07:12 PM
