This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Sep 2006
How to perform a S7-300 overall Reset
I want to reset my S7-300 to default settings (default MPI settings), not just perform a memory reset.
Does anybody know if the hardware reset is possible on a S7-300? Thanks J-P |
#2 |
I may be wrong, but I don't think you can change the MPI setting via a reset. I have always done this by changing the MPI setting on my PC to match the PLC and then downloading a new hardware config with the MPI setting I want.
#3 |
OK, usually I change MPI settings by downloading a new hardware config.
Problem is that for the moment I can no longer connect to the S7-300 using the MPI interface. That's why I would try to reset the communication to default settings by a hardware reset to see if this solves my problem. |
#4 |
Which CPU is this ? Some CPU's allow you to change from MPI to DP (a 318 for example)
#5 |
![]() Join Date: Aug 2006
As I remember there is only one thing thats retentive in the CPU even you remove memory card, backup battery or remove CPU from PLC rack: CPU port settings. The only way to change it is to download new hardware or put an memory card with changed port parameters into CPU.
#6 |
My CPU is a 312C V1.0.3 MPIV
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Redundancy on S7 300 PLCs | Eduardo Pelegrin | LIVE PLC Questions And Answers | 11 | August 18th, 2008 03:58 AM |
| Shift register S7 300 | alielectrical | LIVE PLC Questions And Answers | 16 | December 5th, 2005 08:42 AM |
| S7 overall reset (quick question) | Johnny T | LIVE PLC Questions And Answers | 5 | April 15th, 2005 09:30 AM |
| S7 IEC timer - RESET functionality. | JesperMP | LIVE PLC Questions And Answers | 6 | May 28th, 2004 03:26 AM |
| Siemens S7 300 | sparky64 | LIVE PLC Questions And Answers | 3 | May 5th, 2003 03:50 AM |
