This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Feb 2006
pid factors and offsets in siemens
Can you tell me when and where do we use
PV_FAC and PV_OFF used in PV NORM block in PID loop in FB41 of siemsns S7? and similarly LMN_FAC and LMN_OFF in LMN NORM block.What are practical applications of using these factors and offsets in these blocks.what are their uses?what are they for? |
#2 |
![]() Join Date: May 2003
Hello ravilal;
It is a scaling function for the PV input; I've had to use it once to work with a PV that only ranged up to 40%; using the factor and offset for the PV I brought the signal to 0-100% (almost). But noise was also increased. If I had to do it again, I would work on the input transducers instead. Hope this helps, Daniel Chartier |
#3 |
![]() Join Date: Oct 2004
Another good one is if you make pb negative it acts as reverse controller
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| PID GAINS IN SIEMENS 300 series | ravilal | LIVE PLC Questions And Answers | 3 | September 11th, 2006 02:11 PM |
