plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 14th, 2006, 10:55 AM   #1
pauly
Wales
pauly is offline
pauly's Avatar
Controllogix major fault codes
I want to display the reason for a controller major fault on an HMI how do I get the fault type and codes?
__________________
Pauly
Old September 14th, 2006, 11:06 AM   #2
NOP
England
NOP is offline
NOP's Avatar
In Logix5000 press and hold Alt then h,o,o then look at chapter 15 for some sample code.
Old September 15th, 2006, 02:50 AM   #3
pauly
Wales
pauly is offline
pauly's Avatar
Ive seen this, isn't this routine for a program fault rather than hardware fault though?
__________________
Pauly
Old September 15th, 2006, 07:52 AM   #4
SMOKE
United States
SMOKE is offline
SMOKE's Avatar
Old September 15th, 2006, 09:00 AM   #5
Oakley
United States
Oakley is offline
Oakley's Avatar
Don't forget that the GSV is a scanned instruction - it does nothing if not scanned.
If you have a major fault, the logic stops, and therefore the GSV will not execute. The HMI would not read the value.
I find it best to just monitor the communication with a handshake, then if an alarm comes in, someone goes online to interrogate the reason for the disruption.
Also realize that when the major fault is cleared, the process will resume. Be sure that you have a fault routine that sets the process in a safe mode.
Old September 15th, 2006, 09:47 AM   #6
pauly
Wales
pauly is offline
pauly's Avatar
Could I put the GSV instruction within the controller fault handler
__________________
Pauly
Old September 15th, 2006, 09:55 AM   #7
Oakley
United States
Oakley is offline
Oakley's Avatar
Yes, but if your controller is not communicating, does it respond to data requests? I don't believe so.
Old September 15th, 2006, 10:20 AM   #8
pauly
Wales
pauly is offline
pauly's Avatar
In my fault routine I bring a bit on to indicate controller fault, this gets communicated to the HMI without problem. I have faulted the controller a number of times but I never see any change in the major fault bits!!!What am I doing wrong?
__________________
Pauly
Old September 16th, 2006, 01:13 AM   #9
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
It would help if you told us more about your logic. Are you using a Program Fault Routine or a Controller Fault Handler? Where is the GSV instruction? What are the parameters? Did you create a User Defined data type? Is there any logic preceding the GSV preventing it from executing?
You must place the GSV instruction in the fault routine to handle "program" faults or in the Controller Fault Handler to handle other faults including loss of critical I/O.
Also you need to select "PROGRAM" for the GSV class parameter and "MAJORFAULTRECORD" for the Attribute. "This" will work for detecting faults in "this" program or in the controller fault handler.
Also, make certain that if you are using the COntroller Fault Handler that you specify your routine as a Main Routine, NOT a fault routine.
OG
Old September 20th, 2006, 03:44 AM   #10
pauly
Wales
pauly is offline
pauly's Avatar
Fault handler
This is whre I have the GSV instruction, inthe controller fault handler, in a routine called fault.
__________________
Pauly
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
TCP/IP Drive for AB ControlLogix in VB or VC Petesong LIVE PLC Questions And Answers 0 November 13th, 2005 09:50 AM
RE: Controllogix on Profibus brumby LIVE PLC Questions And Answers 3 January 11th, 2005 12:14 AM
ControlLogix Fans TimeFluxCap LIVE PLC Questions And Answers 11 September 27th, 2004 06:38 PM
ControlLogix + ControlNet Flex I/O sherman4 LIVE PLC Questions And Answers 2 May 14th, 2004 05:32 PM
ControlLogix: What's the latest intel? akreel LIVE PLC Questions And Answers 6 March 23rd, 2004 09:43 AM
