indirect addressing - fill memory function
kyoq
Sep 2006
Poland
18
I am trying to write a function that fills a memory, for example from byte no. 6 write 100 bytes using certain pattern:
IN value: start address [INT]
byte_count (how many bytes to write) [INT]
byte_pattern (e.g. B#16#FF) [BYTE]
It would help me to understand indirect addressing
thanks
Which plc/cpu? If using Step7 300/400 series, there is a system function that will do this. Do you want to do this "long hand" though to gain familiarity with indirect addressing ?
example
Code:
	L	 W#16#FF
	T	 MB	 1
	CALL "FILL"
	 BVAL :=P#M 0.0 BYTE 1
	 RET_VAL:=MW2
	 BLK	:=P#DB5.DBX0.0 BYTE 500
That move hex ff into marker byte 1, then fills DB5.dbb0 to db5.dbb499 with the hex value.
PeterW said:
example
Code:
	L	 W#16#FF
	T	 MB	 1
	CALL "FILL"
	 RET_VAL:=MW2
Just to streamline it a little bit, you really don't have to use the pointer format in this case for BVAL. Just type in MB1, and it will work the same way. I use "SFC Fill" to clear DBs all the time, and I just load a "0" in a temp int variable, enter it for BVAL, and it works fine.
Here is a fill function that does not use SFC21. Note that there is no error checking so if the db doesn't exist or is too small a CPU error will be generated.
Code:
FUNCTION FC 1 : VOID
TITLE =Fill without using SFC21
VERSION : 0.1
VAR_INPUT
dbBlock : BLOCK_DB ;
iStartByteNumber : INT ;
iNumberOfBytes : INT ;
byFillValue : BYTE ;
END_VAR
BEGIN
NETWORK
TITLE =
	 OPN #dbBlock; //Open DB to use
	 L	 #iStartByteNumber; //start byte number..
	 SLD 3; //convert to pointer format
	 LAR1 ; //and use AR1 for indirect addressing
	 L	 #byFillValue; //get fill value
	 L	 #iNumberOfBytes; //set up loop count
Loop:	 TAK ;
	 T	 DBB [AR1,P#0.0]; //and write to DB
	 +AR1 P#1.0; //update indirect address to next byte
	 TAK ;
	 LOOP Loop;
END_FUNCTION
Thanks for source, I modified this to fill memory:
FUNCTION FC 70 : VOID
TITLE =
VERSION : 0.1
VAR_INPUT
start_address : INT ; //Initial address
byte_count : INT ; //Ammount of bytes to be write
byte_pattern : BYTE ; //Byte pattern
END_VAR
VAR_TEMP
pointr : INT ;
END_VAR
BEGIN
NETWORK
TITLE =
L #start_address;
L 0;
==I ;
BEC ;
L #start_address;
SLD 3;
LAR1 ;
L #byte_pattern;
L #byte_count;
P: TAK ;
T MB [AR1,P#0.0];
+AR1 P#1.0;
TAK ;
LOOP P;
END_FUNCTION
for inputs:
// CALL FC 70
// start_address:=8
// byte_count :=0
// byte_pattern :=B#16#F
I got an error Event 2x23 ...why ??
A byte count of zero will actually loop 65535 times and you will run off the end of the M area. Did you mean to check for a zero byte count instead of a zero start address ?
Howdy folks, I am an Allen Bradley guy currently living in an Emerson world. Working with Rx3i on PacSystems Machine Edition v. 9.6? i think...
610
Hello, I'm very new to programming with absolutely zero schooling in this field and pretty hands off training in my new role, it's been fun...
663
Hello Friends, I am trying to index M Bits, however GX Works2 is not allowing it with following message. https://ibb.co/zPcqj6M...
1,372
Hi All, which the best way to do the indirect addressing in an optimize DB? Ccurrently this is my partial code inside an FB...
2,267
Hey everyone, Just used the PLC5/Logix migration utility to convert a program, and while addressing the PCEs, I noticed a lot of errors for "XIC...
1,949
