plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 29th, 2006, 05:20 AM   #1
Steve Kemp
Wales
Steve Kemp is offline
Parallel loading Omron CJ1 shift register
Hi all. Say I'm using address W1 as my starting (and end) words in the SFT(010) instruction; does anyone know whether it's ok to "parallel load" W1 from other sources in the program (set a bit or bits, for example)? I need to look at various stages in a linear array of processes, any of which could generate an output bit, and then track all instances to the last bit in W1 for pass/reject action. Thanks, Steve.
Edit: Hmm, I can see this getting complicated, as I'd have to reset the "set" bits when the next shift occurs and that would interfere with the "next" bit in the register. So... how about a one-shot masked move with the mask arranged to match the station number so only the appropriate bit is loaded?
__________________
For the Present is the point at which Time touches Eternity. C.S. Lewis.
Old September 29th, 2006, 07:00 AM   #2
gtsuport
United States
gtsuport is offline
Just a thought, you could DIFU the W1.xx bit with the "shift" bit. You would need the DIFU instruction before the SFT instruction.
Hope this will help.
Old September 29th, 2006, 07:07 AM   #3
Steve Kemp
Wales
Sounds right to me. If I follow you, I'd need to latch the "on" state for the process stage in question and then gate that state via a difu (when the shift operation is required) into the appropriate W1 bit (as a coil instruction).Thanks. Steve.
__________________
Old September 29th, 2006, 08:12 AM   #4
chavak
Malaysia
chavak is offline
chavak's Avatar
Steve,
If I get you right, you have different processes to be accomplished to determine the end result at the end of its index.
I would rather use Word Shift for this application. It hold all the actual state of the individual results till the process end.(Easier for tracking/trouble shoot).
A 'W' word can hold up to 16 results, say for example you have 10 indexes before the process complete I may use a block of W words start from say W0 ~ W9.
Regards
_______
Old September 29th, 2006, 12:12 PM   #5
gtsuport
United States
gtsuport is offline
Steve,
Yes, you understand what I was suggesting.
Let me know if you have any other questions.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Conveyor window reserve, 1st come 1st, FIFO or Shift Register? cmet LIVE PLC Questions And Answers 16 August 31st, 2006 02:14 AM
Make shift register with ladder solution sis LIVE PLC Questions And Answers 7 October 28th, 2005 07:36 PM
Bit shift register for Siemens S7 Dutchass LIVE PLC Questions And Answers 16 March 29th, 2005 01:45 PM
Shift register Divad016 LIVE PLC Questions And Answers 6 November 11th, 2003 07:52 PM
Shift register assistance (Modicon) Bob Bass LIVE PLC Questions And Answers 2 May 13th, 2003 01:20 AM
