This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Need some help configuring an Ethernet control module(1756-ENET)on a ControlLogix 5550. I have con through several steps in RSLinx Classic and can not communicate through the module. I can communicate through the serial port but I need to be able to communicate through the Enet Module. I think I need to configure an IP address for the module but I am not sure how to do that.
#2 |
![]() Join Date: Oct 2006
The module must have an IP address to communicate with it through RSLinx. You can use the "BootP" application to set the IP address of the module. Run the application on your computer and reset the power on the Ethernet Module. You should see it report its MAC ID to BootP. Then associate the MAC ID to the IP address you want the module to have.
There will also be a printed tag on the Ethernet Module with the MAC ID. You will have to remove the module to see it though. Hope that helps. |
#3 |
You can also connect through the serial port and configue the IP address manually.
#4 | |
Quote:
#5 |
Here is the Link to the Rockwell Knowledgebase which shows you how to do it both ways:
http://domino.automation.rockwell.co...5?OpenDocument |
#6 |
Cool! Thanks for the help.
#7 |
Page 3-5 of the user manual shows how to assign IP address using DF1 driver in RSlinx
http://literature.rockwellautomation...m001_-en-p.pdf |
#8 | |
Quote:
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| plc5 with AB 1771-DB basic module, its urgent plz help me | nileshsurya | LIVE PLC Questions And Answers | 6 | July 20th, 2005 01:45 AM |
| A1N with AJ71c24 multilink Module Errors | dlvernon | LIVE PLC Questions And Answers | 0 | May 29th, 2005 11:48 PM |
| Help in configuring Woodhead's backplane module for AB ControlLogic PLC. | vaidyaas | LIVE PLC Questions And Answers | 2 | April 25th, 2005 12:42 AM |
| Control Logix Ethernet | ben | LIVE PLC Questions And Answers | 2 | August 22nd, 2003 03:49 PM |
| Configuring Siemens 431 An. Inp Module?? | hitit | LIVE PLC Questions And Answers | 2 | July 30th, 2002 07:10 AM |
