This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
info
Sorry the questions were a bit blunt and formal, I have read the PLC live tutorial and learn't alot. But some of the information I am trying to accuire still isn't evedent. I guess it is the way the question has been asked in the first place. The only thing I can say in response is I'm having a blonde moment.
In the tutorial there was no clear mention of the resolution and relationships between analogue I/Ps and O/Ps or word length. I have read books and donot know where to look next. Please can you even tell me where to start looking? Please! |
#2 |
![]() Join Date: Apr 2002
As someone else said, Why is it the British schools that get hung up on obscure or obsolete terminology.
First off, I/P and O/P are NOT the standard abbreviations for input and output. If your instructor or text is using it, they're wrong. I/P is usually the abbreviation for current-to-pressure (usually followed by the word "transducer"). Second, your question is poorly worded (or punctuated). I can't tell if you are comparing analogs to inputs & outputs (by which do you mean bits?), or are wondering about analog I/O (the correct abbreviation for inputs/outputs). The phrase "Word Length" is also meaningless. 1 Word = 2 Bytes = 16 bits. All that complaining aside, here is PART of you answer. Analog I/O modules convert an analog signal (which can have ANY value in a certain range) into a digital (binary) representation. Think of the difference between Real Number (analog) and integers. The most common Analog I/O is 12-bit resolution. This produces converts 0-10 volts into an integer number ranging from 0-4095 ( =2<sup>12</sup>). 14-bit and 15-bit resolution are also common. with this knowledge, I'll leave it to you to crank out the math as to what % the incoming singal (0-10 V) has to change by to be able to "see" the change in the digital signal. It's different for each bit-length of resolution.
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Getting Siemens PLC Pricing Info on the Internet | David Torrens | LIVE PLC Questions And Answers | 10 | November 7th, 2004 04:39 AM |
| thanks for the siemens info guys | andrew1983 | LIVE PLC Questions And Answers | 3 | November 25th, 2003 06:38 AM |
| Scanning barcodes to retrieve info | JStrang | LIVE PLC Questions And Answers | 5 | June 17th, 2003 10:32 AM |
| Minimum info required when posting new topics. | JesperMP | LIVE PLC Questions And Answers | 8 | May 24th, 2003 07:36 AM |
| Contractor info.... Any input appreciated | HootnHoller | LIVE PLC Questions And Answers | 28 | February 28th, 2003 06:33 PM |
