plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old December 28th, 2006, 03:58 PM   #1
SCRUFF
United States
SCRUFF is offline
Control Logix - Redundant Processors
I have a PLC setup that is currently running two (A Redundant) Control logix Processors - a Primary and Seconday.
One important note to mention is that I am a newbie to Control Logix and this is my first Redundant Processors. I am trying to test the swapping of processors by disconnecting the fiber on the Primary Processor to see if the Secondary picks up. It does swap but the Secondary CPU does not swap to run mode. you have to physically select RUN for theSecondary and the same when swapping form the Secondary to the Primary.
Can any guru help me out on how to get the Processors (either one) to swap and come up running after the swap???
THANK YOU...
Old December 28th, 2006, 05:05 PM   #2
Black Jack
United States
Black Jack is offline
If the processors are set up correctly and both powered up, one should indicate primary the other secondary on the led display. Sometimes it takes a few minutes after power up to sync the two. The first chassis powered up will be the primary.
After the two are synchronized, kill the power to the primary and the secondary should automatically become the primary and continue running the logic as if nothing happened. When the power is restored, that PLC will sync back up and become the secondary.
If you disconnect the fiber connection, you are eliminating the synchronizing functionality of the two processors and it will probably go into some non-redundant state and unable to switch over.
Old December 28th, 2006, 05:11 PM   #3
Contr_Conn
United States
Contr_Conn is offline
Contr_Conn's Avatar
If you want test switchover, then disconnect controlnet or ethernet cable, don't touch redundancy fiber.
If fiber disconnected secondary will disqualify and redundancy will not switch over if primary turned off.
Old December 29th, 2006, 12:42 AM   #4
rPraveenkum
India
rPraveenkum is offline
rPraveenkum's Avatar
Redundancy has to tasted by Killing power to primary, disconnecting the controlnet communication
Note:-
when changing the mode of the primary processor will also changes the mode of the secondary processor
__________________
PRAVEEN KUMAR
http://www.praveen.envy.nu
Life is like butterfly, handle with care - Praveen
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Power Flex, Drive Logix and Control Logix Tim LIVE PLC Questions And Answers 2 January 4th, 2007 06:37 PM
Control Logix Redundant System plcnovel LIVE PLC Questions And Answers 3 August 22nd, 2006 02:12 AM
Producer Consumer Messging between Control Logix & Compact Logix plcnovel LIVE PLC Questions And Answers 15 July 24th, 2006 11:04 AM
Honeywell Control builder Sychronization on redundant servers asim_rana LIVE PLC Questions And Answers 1 August 11th, 2005 10:08 AM
Control Logix Redundant System SHINE LIVE PLC Questions And Answers 7 April 3rd, 2004 02:54 AM
