This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Sep 2006
Something about Mitsubishi FX2N programming
Hi guys,
I've just got a software & FX2N mitsubishi PLC today, I'm trying to get familiar with the s/w environment. 1) I'm trying to create a counter and a timer, but I can't find the timer symbol at the top of the software, where it is hiding? 2) I try to program by typing the instruction (like AB ASCII format), Input contact i type LD X0, output I type OUT Y0, but I can't type connter or timer, anyone knows what's the correct code? |
#2 |
In ladder mode use the output symbol (F7).
For the address type the timer or counter you want to use, then a space then the value you want to enter. For example to use counter 3 with a preset value of 5 it would be C3 K5. In instruction list it would be: OUT C3 K5 |
#3 | |
Quote:
Thanks a lot, i got it
#4 |
1) May I ask, how can I create another subroutine, referring to the attached picture, I've a MAIN routine, I want to add another Alarm routine. 2) Do I need to use a JUMP to subroutine if I have 2 or more routines? (AB RSLogix 500 needs that). Thank you. |
#5 |
Its not possible.
Confusing huh! I love GX Developer
__________________
Regards Dave "When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity." Albert Einstein (1879-1955) |
#6 | |
Quote:
So I have to chunk the few hundred lines of code in a main ladder only?? |
#7 | |
Quote:
If I could change one thing about GX Developer that would be it. |
#8 | |
Quote:
This is apply to all Mitsubishi PLC or the software limitation? Last edited by flyers; January 11th, 2007 at 08:14 AM. |
#9 |
Flyer/Potter,
Actually, it is the CPU that limits you from using multiple programs. If you were to use a Q01 series (or higher), you can. The software itself (while certainly not the most user-friendly out there) is not your limiting factor. Steve |
#10 | |
Quote:
After using Mitsubishi & Yokogawa PLC software, I still very much in love with AB!! |
#11 |
Yes,
Unfortunately it applies to all f series processors. Subroutines in the q series not sure about the a series. Marc |
#12 |
While I can't say definitively, I believe the Q series is the only one that features subroutines. Having worked with many of the A series as well, I have never seen them there, either.
Steve |
#13 |
Q, QnA, QnAS allow creating multiple program files.
other CPUs don't (A, FX). working on A series controller and 18000 steps, all in just one file sure makes you curse those who didn't think of possibility of spitting it up...
#14 |
A sort of way I have found for splitting up subroutines - or for that matter different parts of the program is by putting statements in the left hand margin.
If these are quite verbose, it actually appears to split the left bus line and leaves subroutines and routines seperated from the rest of the program. As you then scroll down you can see where one section ends and another starts |
#15 |
You can also create a subroutine (even though it is still in the main program) by using an S coil. When the S coil is true, anything after the STL instruction that matches that coil will execute till you reach the next RET statement.
ie out S5 STL S5 RUNG RUNG RUNG RUNG RET The rungs between STLl5 and RET will only execute when S5 is true, S5 can be anywhere in the program, not just above STL l5. (NOTE, outputs and data will remian in the last state the subroutine was scanned unless turned off in another section of code so be careful, I make the last rung of the STL (right before the RET a reset of all data and outputs that should not retain "last scanned states" But they are still in the main program so it doesn't really split them up visually for you like a subruitine in RSlogix They are handy though Marc |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Mitsubishi FX2N PLC & HMI communication | e_pramod | LIVE PLC Questions And Answers | 15 | February 12th, 2012 03:41 AM |
| Mitsubishi PLC FX2N with modbus | Platootod | LIVE PLC Questions And Answers | 5 | February 6th, 2012 07:48 AM |
| Mitsubishi Fx2n Working With Protool | LEF | LIVE PLC Questions And Answers | 3 | March 12th, 2008 04:11 AM |
| mitsubishi FX2N | topalisg | LIVE PLC Questions And Answers | 4 | June 19th, 2006 01:53 PM |
| Mitsubishi Fx2n Working With Protool | LEF | LIVE PLC Questions And Answers | 0 | March 30th, 2006 07:20 AM |
