Although it is only a small I/O plc and obsolete and the software will probably be Medoc, it is still of some use to someone that would like to learn Mitsubishi.
It is programmed using the 'still used' SC-09 cable and the instruction set is almost the same as modern mitsubishi FX series plc's
In fact, the Mitsubishi FX-16MR-ES/UL is a very powerful plc with a lot of math functions the middle range FX series still dont have.
Someone somewhere would buy it.
