1756-EWEB Cards
matger
Jan 2007
Edmonton
Hello, this is my first post on this forum so i hope someone could give me a helping hand :)
I have 2 AB 1756-EWEB/A ethernet cards, one has firmware version 3.006 and one has version 4.003. The card with the earlier firmware works perfectly, but RSLinx sees the card with the newer firmware as an "unrecognized device".
I suspect that the problem is with the versions of RSLinx/Logix5000 that I am running (Linx = Classic Lite v. 2.5 Logix = v. 15) but my boss does not want this project to update to Logix v. 16 (thinks it still has bugs). I have tried using ControlFlash to bring the v.4 firmware back to v.3 but it ain't happening. Does anyone have any idea of what options I have?
Another thing to get rid of the unrecognized device warning in RSLinx: Get the latest EDS file for the device in question.
It should be available from the mfg and can be installed using the utilities within RSLinx Tools > EDS Hardware Installation Tool.
This is just general advice, I don't know how applicable it is with regard to your revised EWEB card.
This is an easy fix; you need to download and register the EDS file for the 4.x firmware version of the 1756-EWEB.
Point your browser to http://www.ab.com/networks/eds
Click the "EtherNet/IP" selector and type "1756-EWEB" into the Catalog Number field.
The search will return EDS files for the 1756-EWEB firmware revisions 1.x, 2.x, 3.x, and 4.x. You want the EDS file for version 4.1. Click the "Download File" button and save it somewhere you can find it.
The file name is 0001000C007D0400.eds
Next, run the EDS Registration Wizard (shut down RSLinx and RSLogix first.).
Start -> Programs -> Rockwell Software -> RSLinx -> Tools -> EDS Hardware Installation Tool.
Follow the prompts to install the EDS file that you just downloaded.
When you restart RSLinx, the 1756-EWEB should be recognized correctly by the RSWho browser.
I walked a customer through this very thing today; he had RSLinx version 4.2 on his machine and bought a new 1756-ENBT v4 module that wasn't supported until RSLinx 2.50.
But installing RSLinx 2.50 didn't appear to also register the EDS file for the new module. A quick search-download-register and that did the trick.
Does anyone have downloads of the TN 42799 and TN 49389 technotes? They are no longer available on Tech Connect.
1,632
I have updated the firmware of the EWEB module first to 5.001 then to 4.016. I have updated the firmware of the 1756-L73 to v28. The device is...
1,517
Hello, There used to be a toolkit available through Allen-Bradley for the 1756 EWEB card to assist the development of webpages. Allen-Bradley...
1,508
hi, i follow the manual to setup server and client for 1756-eweb card but i have some question, is there anyone who have program for both server...
1,076
Does anyone have a sample html file for the 1756 eweb module? I think I'm having a syntax issue. Tags aren't showing up.
2,107
