This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
How to Ask Questions The Smart Way
Today I came across a very useful document regarding participation in Forums like this one. It is specifically about PCs and Open-Source software, but it is just as applicable to Automation.
It should be read by every first-time poster, and will be useful (and entertaining) to long-time members as well. |
#2 |
amusing read.
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity." - Donald A. Adams |
#3 |
To summarize the before-mentioned article,
How To Ask Questions The Smart Way, by Eric Steven Raymond Before You Ask Before asking a technical question by e-mail, or in a newsgroup, or on a website chat board, do the following:
Choose your forum carefully Be sensitive in choosing where you ask your question. You are likely to be ignored, or written off as a loser, if you:
On mailing lists, newsgroups or Web forums, the subject header is your golden opportunity to attract qualified experts' attention in around 50 characters or fewer. Don't waste it on babble like “Please help me” (let alone “PLEASE HELP ME!!!!”; messages with subjects like that get discarded by reflex). Don't try to impress us with the depth of your anguish; use the space for a super-concise problem description instead. One good convention for subject headers, used by many tech support organizations, is “object - deviation”. The “object” part specifies what thing or group of things is having a problem, and the “deviation” part describes the deviation from expected behavior. Stupid: HELP! Program doesn't work properly on my laptop! Smart: RSLogix does not run on my laptop Smarter: Rockwell RSLogix version 5.5 will not run on my Dell Inspirion Windows 2000 laptop. Write in clear, grammatical, correctly-spelled language. More generally, if you write like a semi-literate boob you will very likely be ignored. Writing like a l33t script kiddie hax0r is the absolute kiss of death and guarantees you will receive nothing but stony silence (or, at best, a heaping helping of scorn and sarcasm) in return. If you are asking questions in a forum that does not use your native language, you will get a limited amount of slack for spelling and grammar errors — but no extra slack at all for laziness (and yes, we can usually spot that difference). Also, unless you know what your respondent's languages are, write in English. Busy hackers tend to simply flush questions in languages they don't understand, and English is the working language of the Internet. By writing in English you minimize your chances that your question will be discarded unread. Be precise and informative about your problem
Courtesy never hurts, and sometimes helps Follow up with a brief note on the solution If You Can't Get An Answer: If you can't get an answer, please don't take it personally that we don't feel we can help you. Sometimes the members of the asked group may simply not know the answer. No response is not the same as being ignored, though admittedly it's hard to spot the difference from outside. In general, simply re-posting your question is a bad idea. This will be seen as pointlessly annoying. Have patience: the person with your answer may be in a different time-zone and asleep. Or it may be that your question wasn't well-formed to begin with. There are other sources of help you can go to, often sources better adapted to a novice's needs. How To Answer Questions in a Helpful Way: Be gentle. Problem-related stress can make people seem rude or stupid even when they're not. Reply to a first offender off-line. There is no need of public humiliation for someone who may have made an honest mistake. A real newbie may not know how to search archives or where the FAQ is stored or posted. If you don't know for sure, say so! A wrong but authoritative-sounding answer is worse than none at all. Don't point anyone down a wrong path simply because it's fun to sound like an expert. Be humble and honest; set a good example for both the querent and your peers. If you can't help, don't hinder. Don't make jokes about procedures that could trash the user's setup — the poor sap might interpret these as instructions. Ask probing questions to elicit more details. If you're good at this, the querent will learn something — and so might you. Try to turn the bad question into a good one; remember we were all newbies once. While just muttering RTFM is sometimes justified when replying to someone who is just a lazy slob, a pointer to documentation (even if it's just a suggestion to google for a key phrase) is better. If you're going to answer the question at all, give good value. Don't suggest kludgy workarounds when somebody is using the wrong tool or approach. Suggest good tools. Reframe the question. Help your community learn from the question. When you field a good question, ask yourself “How would the relevant documentation or FAQ have to change so that nobody has to answer this again?” Then send a patch to the document maintainer. If you did research to answer the question, demonstrate your skills rather than writing as though you pulled the answer out of your butt. Answering one good question is like feeding a hungry person one meal, but teaching them research skills by example is teaching them to grow food for a lifetime. Last edited by Lancie1; February 13th, 2007 at 07:44 PM. |
#4 |
Good stuff. I like the how to answer part too.
__________________
Mickey If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else. ----- Chinese Proverb |
#5 |
![]() Join Date: Feb 2007
my first reply ,try it
#6 | |
Quote:
英語がインターネットの言語であるとだれが言うか。
__________________
Regards Paulus "Nobody notices what I do, until I do it wrong" |
#7 |
Well written and full of truth. Saw myself in there a few places.
May be worthy of a sticky thread.
__________________
“The bitterness of poor quality remains long after the sweetness of low price is forgotten” – Benjamin Franklin |
#8 |
![]() Join Date: May 2003
Paulus,
The listed document did and don't you beleive everything you read on the net?
__________________
"It is the tragedy of the world that no man knows what he doesn't know - and the less a man knows, the more sure he is that he knows everything." Author Unknown |
#9 |
![]() Join Date: Jul 2004
I'll bet more Japanese know English than English speaking people know Japanese.
#10 |
Thanks, Ken, for bringing that to my attention.
I read the whole thing, agree with it, and actually re-phrased a question to a support line this morning as a result of having read it. Good stuff. Dan |
#11 | |
Quote:
__________________
"Making no mistakes is what establishes the certainty of victory, for it means conquering an enemy that is already defeated." -- Sun Tzu My LinkedIn Profile: http://www.linkedin.com/profile/view...15&trk=tab_pro My Unitronics Blog: http://forum.unitronics.com/index.ph...blog&blogid=16 |
#12 | |
Quote:
See... this is exactly why you should use English
#13 |
If people didnt ask all these questions then all you old farts wouldnt have anything ta gripe adout!!
#14 | |
Quote:
#15 |
Excellent, Ken. Thanks for this. I found myself saying "Oops, I've made that mistake" more than once!
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Interview Questions | alielectrical | LIVE PLC Questions And Answers | 36 | December 24th, 2011 03:43 AM |
| RSView32 alarm questions | maxtin | LIVE PLC Questions And Answers | 5 | January 9th, 2007 01:04 PM |
| More Simple DeviceNet Questions | Jimmie_Ohio | LIVE PLC Questions And Answers | 9 | July 3rd, 2006 09:50 AM |
| Technical Questions | joeyb23 | LIVE PLC Questions And Answers | 11 | March 3rd, 2005 05:15 AM |
| SLC 500 questions | greg_schnabel | LIVE PLC Questions And Answers | 2 | July 20th, 2004 03:03 PM |
