plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 14th, 2007, 08:53 PM   #1
nur
Malaysia
nur is offline
Smile Ladder diagram PLC OMRON using PID controller
hello..i need ur advice..i'm doing a project about PID controller based on PLC .Now,i quite confuse on how to implement PID in PLC.Can you give an example of ladder diagram using PID algorithm IN PLC..thank you
Old February 15th, 2007, 02:49 AM   #2
BobB
Australia
BobB is offline
BobB's Avatar
Which PLC? The latest ones have manual PID and auto tune 2 degree of freedom PID built in.
You really should look at the manual - all is explained there. Also if you search at this site there are plenty of topics on PID - some very complex - and feed forward also. Lots can be learned by searchibg.
__________________
The Old Pfhaart
Old February 15th, 2007, 03:18 AM   #3
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
Slightly OT
Quote:
What does two degrees of freedom do for you?
Old February 15th, 2007, 03:00 PM   #4
BobB
Australia
BobB is offline
BobB's Avatar
Sounds like a good marketing tool does it not?
Not much actually as I am not into process control in any way and PID, Feed Forward etc therefore do not do much either. However, things could change and then I would have to investigate and find out waht it does.
I can only comment that any temp controllers I have used in the past with this feature have worked pretty well.
Peter, from what I have seen you are possibly the best one here to comment, and you have in the past. There is a vast difference between what you do and a simple temperature controller.
I rather enjoy designing and building generator systems actually rather than process control or motion for that matter. The only process control job I did I did not enjoy because I had to work alongside/fight with Honeywell. They are very good at coming up with a load of you know what when they are in trouble or behind to apportion blame and direct attention in another direction. Much more comfortable with where my expertise lies.
__________________
The Old Pfhaart
Old February 15th, 2007, 05:30 PM   #5
rdrast
United States
rdrast is offline
rdrast's Avatar
Auto tune in PLC's (and even 'Speed Loop Autotune' in drives) is mostly another marketing slogon. I've never found any 'auto-tuner' to actually work well, except those in dedicated temperature controllers.
The very phrase generally just makes me nervous.
Old February 16th, 2007, 01:31 AM   #6
nur
Malaysia
nur is offline
Omron PLC
i'm doing using OMRON PLC..did you know.?Can you help me..
Old February 16th, 2007, 02:20 AM   #7
khirad
Pakistan
khirad is offline
Yes, I can help you. I have made several programs in Omron usig PID functions. Please contact me directly on khirad@khi.wol.net.pk
Old July 8th, 2008, 07:14 PM   #8
tel
United Kingdom
tel is offline
I'm pretty much doing the same thing.
Building a PID using ladder programmming (avoiding using the built in PID) . Can anyone help?
Also I need a PLC simulator that can read input text file. The ones that I found out there only have logics. I need to force in and out real values
Old July 14th, 2008, 12:34 PM   #9
paraffin power
England
paraffin power is offline
paraffin power's Avatar
Hi tel
1. Why?
2. Which platform?
Pp
__________________
Whatever hits the fan will not be evenly distributed.
Old August 28th, 2008, 11:52 PM   #10
tel
United Kingdom
tel is offline
1. As a project, since the PID blocks that comes with the PLC is write protected.
2. using siemens step7.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens or Omron? Gromit LIVE PLC Questions And Answers 35 November 14th, 2017 10:44 AM
information about the siemens, modicon, omron plc siva_maddala LIVE PLC Questions And Answers 3 June 30th, 2006 09:38 AM
learning PID for Allen-Bradley ... Ron Beaufort LIVE PLC Questions And Answers 9 August 23rd, 2005 01:40 PM
plc ladder diagram request sweetman1 LIVE PLC Questions And Answers 21 May 24th, 2005 06:14 PM
Wanted technical support for Omron PLC (Sysmac: C 60 K) kailashmariappan LIVE PLC Questions And Answers 0 December 1st, 2004 11:37 AM
