![]() ![]() ![]() ![]() This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() ![]() Join Date: Mar 2007
convert pnp to npn signal for plc input
does anyone know how to convert a pnp signal to a npn? for a plc input.besides using a relay.
#2 |
pnp to npn
npn is a common negative terminal to your outputs and inputs.
#3 |
__________________
TURCK Network I/O Guy, Banner Wireless knowledge, & Red Lion HMI stuff! Yes I am the techie geek for the local Rep Firm Automated Dynamics Corp covering the states of TX, OK, AR, LA, MS, part of TN, and a little bit of Mexico. |
#4 |
What is wrong with using a relay? You could go with solid state or an opto if you are concerned with the usual downfalls of a standard relay.
The TURCK smart plug looks pretty neat but I bet it has a higher cost that you were anticipating. |
#5 |
Joe
What do those smart plugs cost, anyways? |
#6 |
Search the site for "pull-up or pull-down" resistor, it can be done with one resistor. If a 3 wire device then just reverse the logic.
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand." |
#7 |
connect ur ground signal thru a resistor with 1.2K,1/2 W with ur PNP signal and pull down to npn signal.reverse the logic in ur plc
#9 |
abwiz,
Sorry for the my delay. The Mrs. & I went to New Orleans for the weekend and she wouldn't let me take along my brain, I mean Laptop. The price on these Smart Plugs from TURCK is $48 and they have well over 50 in stock of each type. That maybe a little steep, but as always in this industry that we are in, everything is negotiable. Thanks, Joe_WaZoo
__________________
#10 |
![]() ![]() Join Date: Jun 2005
Signal Inverter
I have used the Phoenix Contact DEK-TR/INV for many applications where invertering signals. Converts PNP to NPN and vice versa.
See attachment |
#11 |
I generally simply use a pull up resistor and invert the state in the PLC.
If you want more sophistication use an opto isolator chip. A simple 6 legged I.C. If you want to you can mount it in a plastic enclosure available from most terminal suppliers. Even add a LED to indicate status. |
#12 |
![]() ![]() Join Date: May 2005
I used one of the turck sensors npn to pnp sensors today. We ran completely out of pnp sensor that we use on the line. We had several npn sensors on the shelve they had all the rest of the same specs. I agree with you about the convertor is a little on the high side$ . The way i see it that putting a inline quick connector is alot faster then installing a relay to flip the state. I would much rather get complains about spending money vs complain about downtime anyday. I alway keep 1 of each on the shelve (npn to pnp) or (pnp to npn) We have alot of different equipment(us,european,australia,etc). You really never know what kind of sensor you will run into.
#13 |
![]() ![]() Join Date: Feb 2011
I'd also recommend TURCK smart plugs. I think output converter version should fit your application, but it's a little more expensive at $54.50
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
NPN Vs PNP Proximities??? | Eswar | LIVE PLC Questions And Answers | 3 | May 13th, 2006 10:54 AM |
Sinking Input cards | Lead Maintenance | LIVE PLC Questions And Answers | 3 | March 8th, 2006 04:49 AM |
NPN and PNP Sensors | Don_Dubé | LIVE PLC Questions And Answers | 15 | July 10th, 2004 07:55 PM |
Need simple circuit to convert NPN output to 2 PNP output | yctiew | LIVE PLC Questions And Answers | 5 | September 30th, 2003 07:27 AM |
how do I 'queue' machines using PLC & relays | hickman | LIVE PLC Questions And Answers | 42 | September 2nd, 2003 10:16 PM |
