plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 1st, 2007, 05:59 PM   #1
diat150
United States
diat150 is offline
AB slc5/04 communication
hello all, I have a slc5/04 that i need to download the logic from. I am trying to figure out what I need to communicate with this bad boy. it has a panelview 1000 connected to the rs232 port. I tried disconnecting the panelview and doing a autconfig with the rs232 driver using a regular cp3 cable and it did not work. I know that you need this cable:
http://www.rockwellautomation.com/su...84-PCMK_IM.pdf
to use the dh programming port but I was wondering f there was any way around buying the expensive cable?
Old May 1st, 2007, 06:02 PM   #2
Christoff84
Canada
Christoff84 is offline
Christoff84's Avatar
You can try using the AB PIC driver with the cp3 cable. Most likely if the DF1 driver didnt work then the serial port is set to DH485.
Old May 1st, 2007, 06:07 PM   #3
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
What is the exact part number of the panel view? The part number will tell you what the communication protocol is. DF1 or DH485
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity."
- Donald A. Adams
Old May 1st, 2007, 06:13 PM   #4
diat150
United States
diat150 is offline
Im not sure of the part number, I will have to get that next time. so it sounds like I should be able to talk with the processor if the serial port is setup as rs232?
Old May 1st, 2007, 06:26 PM   #5
Christoff84
Canada
You will be able to talk to the PLC no matter which protocol it is running. It will just effect which driver you use in RSLinx.
Old May 1st, 2007, 06:59 PM   #6
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
Exactness begets precision
If the PanelView part number ends in 5 or 9, it's a DH485 protocol unit and you need to use the "1747-PIC/AIC+" driver in RSLinx with an integral RS232 port on your PC.
If the PanelView part number end in 16, it's a DF1 Full Duplex protocol unit and you can use the DF1 Full Duplex driver in RSLinx.
Because you already tried the DF1 Full Duplex driver and were unsuccessful, it's a safe bet that the SLC-5/04 Channel 0 is configured for DH485 protocol.
You have two additional options:
1. The "PIC driver" can be difficult to configure in Windows 2000/XP because of the hardware access it requires. A-B makes a 1747-UIC USB/DH485 converter that converts between DF1 protocol on USB and DH485 protocol on RS232 or RS485. This is the choice for most modern DH485 users.
2. The PanelView Standard terminals with version 3.0 or better firmware support ATA Flash memory cards, including CompactFlash cards in PCMCIA Type II carriers. This is my preferred method for uploading and downloading *.PVA configuration files to and from Standard PanelView Terminals.
__________________
- "Simpler is better, except when complicated looks really cool."
Old May 1st, 2007, 07:43 PM   #7
diat150
United States
diat150 is offline
thanks for the help. I did have trouble getting the aic driver to install. I had to log onto my adminstrator account for it to even load up. Not sure if it will even work right when i do get back around to it.
Old May 1st, 2007, 09:25 PM   #8
OZEE
United States
OZEE is offline
Quote:
Just a nit-picky technicality... You download TO a PLC, you upload FROM it. You'll save lots of future confusion if you'll reference the directions correctly.
There are lots of examples of people uploading to a PLC and wondering why the processor memory is blank. Or downloading from a PLC and wondering why their offline program changes are gone.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Communication between Siemens PLC en AB PLC through profibus? pietervdb LIVE PLC Questions And Answers 3 March 14th, 2007 07:16 AM
Modicon TSX Microscan to AB Micrologix communication kulkago1 LIVE PLC Questions And Answers 2 July 27th, 2006 09:44 AM
Communication on ethernet between AB PLC and Siemens PLC Chandrashekhar_basap LIVE PLC Questions And Answers 4 May 28th, 2006 04:03 PM
AB communication cable indra LIVE PLC Questions And Answers 10 September 24th, 2005 06:33 AM
Rs485 Communication With Micrologix Ab pcontrol LIVE PLC Questions And Answers 1 January 2nd, 2003 12:50 AM
