plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 29th, 2007, 12:23 PM   #1
Outrage
England
Outrage is offline
Cable for Panelview +
Hi All,
Can you tell me if the cable you need to communicate with RSView ME through the laptop serial port to a panelview+ serial port is a standard null modem cable?
I have a null modem cable that i use to connect from RSLogix 500 to SLC5/05's that works in liu of the official CP3 cable and would like to know if you can use the same cable.
Best Regards,
Lee
Old May 29th, 2007, 12:27 PM   #2
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
For reasons that are as obscure as the mists of time themselves, PanelView Standard and PanelView Plus terminals have "DCE" type serial ports. You must connect them to your PC's serial port with a straight-through cable, not a null-modem cable.
__________________
"Intelligence is the capacity to know what we are doing and instinct is just instinct. The results are about the same."
Old May 29th, 2007, 01:06 PM   #3
OZEE
United States
OZEE is offline
Or even easier is the ethernet connection. Without a switch/hub, you'd just use a cross-over cable.
Old May 29th, 2007, 04:04 PM   #4
Outrage
England
Outrage is offline
Quote:
Cheers Ken/OZEE.
I've just purchassed the software and a spare panelview as spares/to give me something to play with. So i'll give the ethernet a blast, we've got a fibre/ethernet switch at each station so there are plenty of free ports to plug into.
I don't have the original program the plan was to pull off the .mer file's off each panelview for safe keeping. Will not having the original programs cause me any problems conecting to the panelview? - I was used to the older panelview's/software. and i've yet to play about with ME.
Cheers Chaps,
Lee
Old May 30th, 2007, 03:37 AM   #5
Gil47
New Zealand
Gil47 is offline
Gil47's Avatar
Quote:
Lee
It is my understanding that you can't upload from the panelview plus unless you already have a copy of the program on your computer and you will need it supplied by the origional suppliers as a back up file which is an *.API file
Old May 30th, 2007, 10:11 AM   #6
rgurin
United States
rgurin is offline
rgurin's Avatar
To clarify Gil47's statements:
1. You can upload an existing .mer file from the PanelView Plus, even if you do not have the original file. All you need is a connection between your PC and the PanelView(s).
2. The backup application can be transported via email as a .apa file.
3. If you do not have a copy of the original application (or cannot get the .apa file from the supplier), you can search this forum to find several threads dealing with a way to convert the .mer file so that most of the application will be useable.
4. FYI, plans are in the works for the next release of RSView ME to contain a feature that will convert .mer files to an application file. However, I believe this will only work for files created in that version of the software.
Rick
Old May 30th, 2007, 10:26 AM   #7
Outrage
England
Outrage is offline
Rick
Hi Rick and Gil47,
Thanks for the info - was a little dissapointed at GIL's post but perked up a bit now! I'm on my off rotation at the minute but will give this a shot when back on shift.
Cheers,
Lee
Old August 2nd, 2008, 10:57 PM   #8
p_logix
United States
p_logix is offline
what kind of panel view do you have? is the serial port DTE or DCE? this will determine what type of cable you need period. The panelviews i have downloaded required A null modem cable. DTE type will require a null modem cable period. a DCE WILL REQUIRE A 9 PIN SERIAL STRAIGHT THROGH. BELL.
Old August 2nd, 2008, 11:34 PM   #9
Mickey
United States
Mickey is offline
Mickey's Avatar
Quote:
p_logix' your a tough nut to crack.
The only Allen Bradley panelviews that require a null modem cable are the Stanard PanelView 300 Micro. All others with serial connection use a straight thru cable.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens PPI cable pinout Doug_Adam LIVE PLC Questions And Answers 8 July 9th, 2012 05:38 AM
1747-UIC / Cat 5 Cable? Caution! Philadelphia Frank LIVE PLC Questions And Answers 20 July 1st, 2011 10:51 AM
Cable needed for Allen Bradley Modem 9300 RADKIT kemppioy LIVE PLC Questions And Answers 1 April 21st, 2006 09:40 AM
Modicon PL7Pro Programming Cable rslimjoco LIVE PLC Questions And Answers 3 February 19th, 2004 01:38 PM
1747-UIC Cable Requirement Philadelphia Frank LIVE PLC Questions And Answers 8 December 4th, 2003 07:38 PM
