This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: May 2007
If anybody know how to configure DL35000 DF1 to DH+, please tell me. I have four SLC500 with 5/04 processors.The PLC comunicates between them via DH+ network at speed 57,6 Kbds trough Blue Hose cable and everything is OK. Now I want connect PLC network with DL3500 DF1 to DH+/DH-485 to my PC in my office wher is the end of Blue Hose cable. Please if anybody have answer how i can do this
#2 |
This should be the manual for the DL3500 http://www.protocolconverter.com/DL3500-UM.pdf
__________________
http://www.patchn.com Industrial Electrical & Maintenance @ www.patchn.com "Tell me and I forget, show me and I remember, involve me and I understand." |
#3 | |
Quote:
The PLC communicates between them via DH+ network at speed 57,6 Kbds and everything is OK. One end of the cable ( Blue Hose) is in office where is a PC. Here is DL3500 and we want connect our network and PLCs to PC in office. RSlinx now couldn't see PLCs. You can see snap shot what RSlinx showed in attachment.
#4 |
What are you using for device in RSLinx?
see picture then change to to match if you have not already done so.
__________________
Mickey If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else. ----- Chinese Proverb |
#5 |
Hello Mickey,
I'm already use device exactly like at the picture. |
#6 |
Well then I would double check the baud rate of your DL3500 serial port and set RSLinx to match (note this is different then the DH+ baud rate). Cable between PC and DL3500 is a null modem cable ( double check)
__________________
#7 |
Baud rate is 19,2k and cable between PC and DL3500 is RS232/USB2.0
#8 |
Since you are using an RS232/USB2.0 interface, the serial port is very likely NOT enumerated as COM1.
My Keyspan USB/RS232 interface enumerates as COM14, and changes depending on which of my 4 USB ports I plug it into. You must determine which logical Windows COM port your serial port is assigned. Start -> Settings -> Control Panel -> System Select "Hardware" tab. Click "Device Manager" button. Scroll down to Ports (COM & LPT).
__________________
"Intelligence is the capacity to know what we are doing and instinct is just instinct. The results are about the same." |
#9 |
I check first which port is using and put same COM in configuraton of the DL3500 and RSlinx.
#10 |
Well, check the DH+ wiring. There should be one 150 ohm resistor between the blue and clear wires on each extreme end of the network (for 57.6 kb/s operation).
Try reversing the blue and clear wires at the DL3500 end.
__________________
#11 |
I chek the DH+ wiring and you can see on the picture, DH+ wiring is OK.I'm trying with resistor and still DL3500 can't see PLCs.
#12 |
Thank you everybody for help.Finally DL3500 can see all nodes in my DH+ network. I try with RS232cable and external power supply without USB/RS232, and is successfull.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Dh 485 | Thomas Franklin | LIVE PLC Questions And Answers | 2 | December 1st, 2006 02:22 AM |
| Dh 485 Again! | Thomas Sullens | LIVE PLC Questions And Answers | 5 | July 7th, 2006 11:35 AM |
| read-write thru dh 485 | labingtone | LIVE PLC Questions And Answers | 1 | September 20th, 2004 07:38 AM |
| DH 485 Cable | Jezz | LIVE PLC Questions And Answers | 3 | May 27th, 2003 07:07 AM |
| DH 485 network | Jezz | LIVE PLC Questions And Answers | 1 | April 9th, 2003 07:33 AM |
