plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 17th, 2007, 10:42 PM   #1
ettikudiappan
Singapore
ettikudiappan is offline
ettikudiappan's Avatar
AB 1734-AENT POint IO issue
We are facing a point IO communication issue intermittently, once in 3 days. While running, the Network Status LED turns flashing red and the Point Bus status LED turns solid red. This is a symptom of wrong configuration of the number of ASCII modules connected to the point IO, but if this were the case the Point IO should always fault.
I changed the Point IO module itself (1734-AENT), the problem occured again. Then we changed the power supply, also same issue.
The Point IO has 5 modules connected to it, 2 RS485 and 3 RS232 modules. The RS485 modules are not used.
Anybody else faced the same issue? We have other POint IO in the plant that work perfectly well.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
AB DeviceNet Scanner Issue (1769-SDN) pickerel LIVE PLC Questions And Answers 5 April 10th, 2018 10:37 AM
AB ML1500 Floating point to integer conversion opamp LIVE PLC Questions And Answers 9 November 29th, 2013 09:51 PM
AB PLC5/80B RIO Flex IO Fault corkers LIVE PLC Questions And Answers 9 September 4th, 2004 02:12 AM
AB past issue Tim LIVE PLC Questions And Answers 39 August 20th, 2004 07:52 PM
AB journey Tim LIVE PLC Questions And Answers 18 December 18th, 2003 07:51 PM
