WallyPrestone
Hello,
I need help for troubleshooting hi current with fault e19 ( following error) , e20 and e22, machine run with normal 3.7 amps and 31 amps analog.
The faults occured in the early morning when machine started
sometime the current went up to 14 or 15 amps and overheat the motor .
Machine continue to run until the rest of the day without problem.
Thank you
Wally
Thank you
Wally
