This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Controllogix function block diagram
I am using the PIDE function in controllogix and the automatically created tags for the PIDE don't seem to be avaliable to the rest of the other routines. Is this a Function Block Diagram thing or am I missing something?
__________________
Pauly |
#2 |
![]() Join Date: Oct 2005
Well, this is going off a year old memory, and I wasn't directly involved in the project at the time. It seems that if a FB was created with controller scoped tags, the FB would not work. Therefore, you had to use program scoped tags. Since they're program scoped, you can't access them from other programs.
This was confirmed with tech support at the time. A major PITA! |
#3 |
![]() Join Date: Oct 2004
I think you created the tag as program scope instead of Controller. In controlLogix, you can have both. Program tags are only available within the actual program and Controller scope tags are available anywhere.
It might sound weird but it is very usefull when you have multiple machines that are identical. You can have all the logic tags to that machine as program tags. Then map in/out. So after you make one machine. Just need to copy and change the map in/out. |
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| FC vs FB, DB | mico207 | LIVE PLC Questions And Answers | 69 | January 26th, 2010 09:34 PM |
| for all the controllogix xsperts (function block help) | ghriver | LIVE PLC Questions And Answers | 10 | June 21st, 2007 11:55 PM |
| ST Help, function & block function | najs | LIVE PLC Questions And Answers | 3 | February 24th, 2006 01:09 AM |
| ControLogix PLC Function Block Diagram programming | wesley szymczyk | LIVE PLC Questions And Answers | 3 | April 24th, 2003 12:49 PM |
| Function Block Diagram Programing | fbeduhn | LIVE PLC Questions And Answers | 3 | November 24th, 2002 08:45 PM |
