plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 20th, 2007, 12:53 PM   #1
neerajpuranik
India
neerajpuranik is offline
neerajpuranik's Avatar
Question RSLinx Classic Lite vs RSLinx Classic
What is the difference between these two?
I have RSLinx lassic lite, PM02 cable & ML1500 processor. Will I be able to communicate (upload & download ) with the ML1500 processor or I need RSLinx classic for that?
__________________
Quote:
Never hesitate to ask foolish questions, as they can be easily handeled compared to foolish mistakes.
Old August 20th, 2007, 01:00 PM   #2
SLC_Integrator
United States
SLC_Integrator is offline
I dont think Lite has the OPC stuff in it.
Classic certainly does.
Old August 20th, 2007, 01:01 PM   #3
Mickey
United States
Mickey is offline
Mickey's Avatar
Yes, RSLinx Lite and RSLogix500 is all you need to upload/download and monitor.
There is no such thing as just RSLinx Classic ( many versions). There is see PDF.
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old August 20th, 2007, 01:06 PM   #4
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
Quote:
Will I be able to communicate (upload & download ) with the ML1500 processor...?
Yes, You will be able to program and communicate with your PLC and upload/download programs and view your data files online using RSLogix and RSlinx lite.
edit: I see I need to type a little faster.
__________________
True craftsmanship is only one more power tool away.
That's the beauty of processors, they don't have emotions they just run code - The PLC Kid.
Old August 20th, 2007, 01:20 PM   #5
neerajpuranik
India
Thanks Mickey for giving me exactly what I needed.
__________________
Old August 20th, 2007, 02:17 PM   #6
jimbo3123
United States
jimbo3123 is offline
There is a such thing as RSLinx Classic. That's what A-B now calls all of the many versions of the "regular" (not RSLinx Enterprise) RSLinx.
The document that you posted was from 2005, before they made the naming change.
Old August 20th, 2007, 02:22 PM   #7
SLC_Integrator
United States
I was about to post the same thing!
They also changed Linx for RSView to Linx Enterprise.
So now you have Linx Classic OEM, Classic Pro etc.
Old August 20th, 2007, 03:17 PM   #8
Mickey
United States
Mickey is offline
Mickey's Avatar
I'll say it again "there is no such thing as "JUST RSLinx Classic"
There is as ( as SLC_Integrator said) RSlinx Classic Lite, RSLinx Classic OEM, RSLinx Classic Pro, RSLinx Classic Gateway, RSlinx Classic Single Node, RSlinx Classic SDK etc.
Its important to know what version. Whenever someone ask "can I do this and that with RSLinx Classic?", the response is always "what version do you have?".
__________________
Mickey
Old August 20th, 2007, 03:37 PM   #9
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
A little OT but....
I don't think there is any thing different at all, if you compare the size of the file (or CD) with Lite, PRO or OEM they are all the same, when you load the key that determines what feature(s) are enabled. If you don't load a key at all it defaults to lite.
So no difference but the key is different
Gateway and others may not be the same
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old August 21st, 2007, 04:07 AM   #10
neerajpuranik
India
Dear SLC_Integrator,
I hope you will pardon my ignorance. Pls tell me in detail what does this OPC stuff means. Is it a part of SCADA like trending, graph etc or something else. If there is a manual pls give me the link too.
Thanks,
Neeraj
__________________
Old August 21st, 2007, 07:31 AM   #11
curlyandshemp
Canada
curlyandshemp is offline
curlyandshemp's Avatar
I recall at one time RSLinx Lite (linx without the activation )would not allow DH+ communications via a 1784-PKTX(D) card. Is this still the case?
__________________
Work to Ride,
Then Ride to Work
I would rather have a bottle in front of me..
than have a frontal lobotomy
Old August 21st, 2007, 08:02 AM   #12
croakus
United States
croakus is offline
croakus's Avatar
I don't believe so...
I've got a desktop pc being used by maint. that has had a pktxd card in it for a few years. One channel is set for DH+ and the other is RS-485.
Mike
Old August 21st, 2007, 09:58 AM   #13
jedft
United States
jedft is offline
Neeraj, OPC allows you to do things like display/modify values in addresses in your PLC using applications such as Excel... or even do custom HMI with VB or the like. So yes, it is "part of" SCADA. You must have some sort of OPC server to do this with the right driver for the PLC you are using. AB provides one with RSLinx. Go here for more info...
http://www.opcfoundation.org
__________________
Arrrrr...It's drivin' me nuts!
Old August 21st, 2007, 10:08 AM   #14
SLC_Integrator
United States
What he said
Note: There is actually 3 subsets in OPC now, OPC-DA (data aquisition) OPC-AE (Alarms & Events) and OPC-HDA (Historical Data Aquisition)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSLINX lite unrecognized device MGuenette LIVE PLC Questions And Answers 6 May 1st, 2007 05:20 PM
RSLinx Classic Lite..... XtremeIN LIVE PLC Questions And Answers 2 November 28th, 2006 09:29 AM
RSLinx pro and RSLinx lite, what is the difference? shaarawi1984 LIVE PLC Questions And Answers 7 September 20th, 2006 08:45 AM
PV 600 Plus - Cockpit Trouble glaw LIVE PLC Questions And Answers 24 June 30th, 2006 11:53 AM
RSLinx Classic 2.5 quit connecting moltra LIVE PLC Questions And Answers 5 June 14th, 2006 02:00 PM
