plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 21st, 2007, 12:38 PM   #1
MAHER
Egypt
MAHER is offline
The difference between (resolver & encoder)
HI every body
I have in my work a more type of machines which uses (RESOLVER) and the other one uses (ENCODER), but i know the concept of working for the (ENCODER) and also i know how can iuse it in the program.The (ENCODER) has 5 terminals as follwing:
1-for 24V
2-FOR GND
3-FEED BACK IN THE FORWORD (24V)
4-FEED BACK IN THE REVERSE (24V)
5-FOR RESETTING.
BUT idon't know any thing about (resolver), so i want to know :
1- the feed back .
2-how can it transact with the plc to determine the position for the motor.
please i want also the construction for it.
thanks for all
maher
Old August 21st, 2007, 01:39 PM   #2
rdrast
United States
rdrast is offline
rdrast's Avatar
Encoders are digital, incremental devices. Providing discrete logic-transition states for each output pulse. Absolute encoders can have many output lines, but are still digital devices.
Resolvers are analog devices, with theoretically infinate resolution of the shaft angle, and are almost inherently capable of reading absolute shaft position.
Resolvers need external circuitry (generally) to supply both source excitation to the windings, and to interpret the phase-difference coming back from the windings.
Old August 23rd, 2007, 04:26 PM   #3
MAHER
Egypt
MAHER is offline
hi
it's not clearly for me this do you have any paper to illustrate the resolver for me which has (the costruction and application ).
thanks for helping
maher
Old August 23rd, 2007, 04:36 PM   #4
allscott
Canada
allscott is offline
allscott's Avatar
http://en.wikipedia.org/wiki/Resolver_%28electrical%29
Resolvers for the most part are being replaced by encoders in my experience.
Old August 23rd, 2007, 04:43 PM   #5
timbo_uk
United Kingdom
timbo_uk is offline
timbo_uk's Avatar
Quote:
Originally Posted by MAHER
HI every body
1- the feed back .
thanks for all
maher
This may help you
http://www.amci.com/tutorials/tutori...s-resolver.asp
Old August 31st, 2007, 01:13 PM   #6
MAHER
Egypt
MAHER is offline
hi
do you have any application for using the (RESOLVER) IN plc?
thanks
Old August 31st, 2007, 07:51 PM   #7
panic mode
Canada
panic mode is offline
panic mode's Avatar
huh...?
it is a position feedback device. any time you can use position feedback, you can count on resolver as posible solution. lookup LVDT for example, it doesn't rotate but basic principle is the same.
application? well, any time you want to measure angle or shaft position. we use them for example in nuclear environment (can't use encoder or anything with electronics)
Old August 31st, 2007, 09:17 PM   #8
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
Resolvers are used in crank presses. Lead or ball screw applications. Carriages. Any application where the absolute position must be known at all time or if the application is prone to shock. Optical encoders are frail compared to resolvers. Now there are magnetic encoders which are just as rugged. There are also SSI encoder that can also provide absolute positions and have a much more standard interface. We sell very few resolver interfaces relative to SSI or incremental encoder interfaces. SSI is the most popular interface now because it works with both linear and rotary feedback devices and with so many different brands. Resolver interfaces require an excitation signal that can vary by voltage and frequency.
Old September 1st, 2007, 01:15 AM   #9
leitmotif
United States
leitmotif is offline
Search the web for BEI Industrial Encoders for Dummies. Has good basic easy to understand explanation.
Dan Bentler
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Difference in teco and encoder pe_vivek LIVE PLC Questions And Answers 1 January 22nd, 2007 11:38 AM
Need encoder advise on used machine. helluvawreck LIVE PLC Questions And Answers 3 July 21st, 2006 02:40 PM
Usage (A,B) shaft encoder (X4) HenryLamboo LIVE PLC Questions And Answers 2 July 21st, 2005 12:43 PM
Resolver vs Encoder jthornton LIVE PLC Questions And Answers 3 May 19th, 2005 03:02 PM
encoders and plcs ready961 LIVE PLC Questions And Answers 20 January 23rd, 2003 08:18 AM
