This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
How to play a .wav file
Does anyone have any ideas on how to go about playing a .wav file after an event occurs? I did search the forum and the newest post was 2 years old. Has anyone done this? Equipment is Allen Bradley SLC series and there is also a small PC connected to the system via RS232 with ethernet capabilities. Thanks in advance for your time.
__________________
Age and treachery will always overcome youth and skill. |
#2 |
I've done it using RSView, what software do you have on the PC? if you have only 500 and linx then you can create a VP application or have some other form of a HMI
__________________
www.PLCTrainer.net PLC Trainers, Communication Cables and Automation Supplies, Allen Bradley ~ Siemens ... YouTube PLC help videos.. http://www.ind-concepts.com/Support_and_Downloads.htm |
#3 |
![]() Join Date: Aug 2005
I don't know if this will help but here is how Siemens does it. Maybe it will give you some ideas.
http://support.automation.siemens.co...rim=&nodeid99= |
#4 | |
Quote:
__________________
#5 | |
Quote:
__________________
#6 |
Another option is to use an alarm horn with recordable memory tied to an output. We have one installed in our casting facillity but we used one of the pre-programmed sirens. I believe it was an Edwards Signal unit.
I did test the recording feature and it did function OK. It might be cheaper than buying some MMI software unless you know how to use VB. Were you planning on using this just in a control room or out in the plant? |
#7 | |
Quote:
I am picturing some sort of application with pre-recorded .wav file messages running on the PC that are triggered by signals from the PLC through a serial connection. Does anyone know of such an application?
__________________
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Can't get RSL to recognize my HMI in lad 2 | AnthonyF8:0 | LIVE PLC Questions And Answers | 7 | February 9th, 2006 07:38 PM |
| am i correct? excel & logix CSV communication. | fusion | LIVE PLC Questions And Answers | 14 | October 19th, 2005 06:18 PM |
| a-b sub routine | jim-garcia | LIVE PLC Questions And Answers | 9 | February 16th, 2005 06:30 PM |
| Sequencers | randy | LIVE PLC Questions And Answers | 42 | September 7th, 2004 08:55 AM |
| Data Tables | bosshen | LIVE PLC Questions And Answers | 5 | April 28th, 2003 06:30 PM |
