plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old August 28th, 2007, 08:07 AM   #1
Michael Bell
United Kingdom
Michael Bell is offline
Mitsubishi GX IEC Developer FEND. END Instructions
Hi all,
I have come across this problem when trying to use a CALL, Pointer and RET in GX IEC DEV. The PLC is an FX3U. The program consists of a number of POU's. I am trying to use a subroutine in one of them. If I write the code and compile it seems ok. However when I download to the PLC I get an error 'RET Instruction not found, even though one exists.
I have uploaded the ladder into GX Dev, and I can see the FEND and it is immediately before the END instruction, I have no control over this.This means that the FEND is after the pointer to the subroutine, which is incorrect.
I have no idea what is happening!
Any ideas, thanks.
Old August 28th, 2007, 01:18 PM   #2
parky
United Kingdom
parky is offline
You should't need to do this, in IEc you create a function block something like test, give it input/output parameters etc. then call the function in one of your other programs as many times as you like (note you can call them the same instance or individual instances the latter will put calls to seperate routines) this will automaticaly compile the code as a subroutine.
in reality all it does is:
a x0
= m2000 (temp variable)
a x1
= M2001 (temp Var)
call P1 jump to sub
a m2003 temp var
= y 0
fend
P1:
do the code
a M2000
a M2001
= M2003
ret
End
You should not have any need to jump to subs as these are really functions you can create just like siemens.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Mitsubishi GX Developer V8.25B & Dell Latitude ATG D620 help. eniltrah LIVE PLC Questions And Answers 5 April 4th, 2011 02:07 AM
Mitsubishi GX IEC Developer Potter LIVE PLC Questions And Answers 0 February 26th, 2007 09:43 AM
GX IEC Developer 6.01, Q-Series, Mitsubishi marvin LIVE PLC Questions And Answers 0 February 4th, 2005 04:29 AM
GX Developer 8 - GX IEC Developer jim5 LIVE PLC Questions And Answers 1 November 28th, 2004 04:50 AM
mitsubishi gx iec developer big belgium bert LIVE PLC Questions And Answers 1 June 1st, 2004 02:50 PM
