plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 11th, 2007, 12:57 PM   #1
SNK
Canada
SNK is offline
SNK's Avatar
Unhappy Fix32 version 7.xx Pushbutton Control
Hey people, I am finishing a changenote on an existing system that uses the FIX32v7.xx, and I need to have the button on my screen be a MOMENTARY button. From what I am using so far, I am using the Script Editor and (Command Button) and can only achieve a "Toggle".
This is not practical for me in my PLC program, so I need the action to be a "Momentary" trigger, not a "Toggle".
The electronic books do not indicate any such animal. Am I missing something?
Please let me know if you understand my question properly,
Thanks....
Old September 11th, 2007, 01:41 PM   #2
Mickey
United States
Mickey is offline
Mickey's Avatar
I do two things:
First I write script as follows
CLOSEDIG FIX:TESTDI.A_CV
PAUSE 1
OPENDIG FIX:TESTDI.A_CV
I also clear, reset, unlatch ( depends on your PLC) the bit in my PLC, that was turned on by FIX after it is used. ( just to be sure its turned off)
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old September 11th, 2007, 03:15 PM   #3
curlyandshemp
Canada
curlyandshemp is offline
curlyandshemp's Avatar
Thanks....
I believe you can creat a script assigned to the push button, where ON ACTION DOWN, SETVAL the bit to 1,
then ON ACTION UP , SETVAL the bit to 0
Thats how I have momentary button on FIX32
Ian
__________________
Work to Ride,
Then Ride to Work
Old September 11th, 2007, 04:10 PM   #4
SNK
Canada
SNK is offline
SNK's Avatar
So would this work?
TOGGLEDIG FIX:TESTDI.A_CV
SETVAL FIX:TESTDI.A_CV=1
Is ACTION DOWN in the script editor?
I am using the bit from the Fix to Latch into a state.
At the end of my state process, I DO-NOT want the Fix32 bit to be enabled still, because I unlatch my state bit with other operands.
Could one of you guys post your actual code for the momentary change? Mickey, Yours looks like it is a code snippet, can I use that other than just change the tag?
Old September 11th, 2007, 04:44 PM   #5
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
Use Mickey's example, I have several Fix 7.0 applications and that's exactly how I do it. Sometimes if you're communicating via serial, the you may have to increase the pause time.
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity."
- Donald A. Adams
Old September 11th, 2007, 05:23 PM   #6
Mickey
United States
Mickey is offline
Mickey's Avatar
So would this work?
Yes, just change Node and tag. Also pause time to suit your application, as Ken pointed out.
__________________
Mickey
Old September 11th, 2007, 09:20 PM   #7
pw3
United States
pw3 is offline
Fix dynamo sets
We're running iFix 3.5, but started out with Fix 6.xx on one of our older apps and then migrated it up to iFix.
Anyway, look in your Dynamo sets (.fds files) for one called "momentar.fds". It should have been put there when you did your install--if not, look at their website it may be there as a free download.
In this set you will find several momentary push button templates. Drag and drop one on your desktop and then edit the script to send a 0/1 to your device. They also make one with a keypad (handy) and some other animated vessels.
Old September 12th, 2007, 06:41 AM   #8
SNK
Canada
SNK is offline
SNK's Avatar
Thanks Guys.
Help as always.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Hydraulic Winch Control shelnian LIVE PLC Questions And Answers 10 May 3rd, 2006 09:51 AM
Dcs, Scada hasnoclue LIVE PLC Questions And Answers 15 April 11th, 2005 06:12 AM
PID - what is it anyway? Ron Beaufort LIVE PLC Questions And Answers 6 May 22nd, 2003 11:21 PM
how often should I trigger the PID? Ron Beaufort LIVE PLC Questions And Answers 11 February 22nd, 2003 10:57 AM
grounding power sources drewcrew6 LIVE PLC Questions And Answers 18 December 12th, 2002 05:16 PM
