plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 13th, 2007, 05:34 AM   #1
tny
United States
tny is offline
tny's Avatar
Question momentary set with td200
hi all;
as you know siemens TD200 panels sets the related bits when pushed a button, and we must reset it from the program.
do you know an easy way for momentarly setting a bit with it?
in my application, i want to push a Fkey for starting a motor in manual mode and release it to stop the motor.
so i had to read the F key, and set an offdelay timer with it and reset the Fkey bit in the same rung. of delay timer filters the cyclic pulses of Fkey (every cycle TD200 sets the bit and PLC resets it, so pulses occur)
timer values above 600ms can filter the pulses (start stops of the motor)
values less than 600 ms still can cause pulses.
do you know a better way for it?
Old September 13th, 2007, 05:43 AM   #2
tny
United States
tny is offline
tny's Avatar
the picture is more understandable i think
Old September 13th, 2007, 12:02 PM   #3
Gazzr
United Kingdom
Gazzr is offline
The buttons can be set to act as a momentary contact via the TD200 setup wizard. You set these at the configuration stage.
(The default is for them to "set bit")
Hope this helps.
Old September 14th, 2007, 03:18 AM   #4
tny
United States
tny is offline
tny's Avatar
i have microwin ver3.2 and there is no such menu in the setup wizerd as you told.
which version are you using?
Old September 14th, 2007, 07:03 AM   #5
Crossbow
United States
Crossbow is offline
Crossbow's Avatar
The TD200 wizard is built into MicroWin. Even in version 3. Check in the Tools list on the left side of the screen.
Current version is 4.0 SP5.
Old September 15th, 2007, 04:23 AM   #6
Gazzr
United Kingdom
Gazzr is offline
Old September 15th, 2007, 11:50 AM   #7
tny
United States
tny is offline
tny's Avatar
ok, i think my version does not support this, my td200 wizard includes only this menus.
Old September 15th, 2007, 03:34 PM   #8
Crossbow
United States
Crossbow is offline
Crossbow's Avatar
Sounds like time for an upgrade...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ServoStar 600 positioning through Profibus and a S7 Program. pietervdb LIVE PLC Questions And Answers 11 August 9th, 2007 06:47 AM
PID Control Versus PLC DjFab LIVE PLC Questions And Answers 11 May 12th, 2007 10:11 AM
Mitsubishi Q Series Modbus TCP module QJ71MT91 set up help req'd... Pocko LIVE PLC Questions And Answers 0 July 30th, 2006 02:45 AM
sew movidrive and ipos plus programming liew_sc LIVE PLC Questions And Answers 18 March 13th, 2006 03:10 AM
toggle logic in 'c' language naishadgosai LIVE PLC Questions And Answers 11 August 6th, 2005 08:53 PM
