This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
STEP7 v5.4 SP3 archiving is busted.
Hi after installing SP3 for STEP7 v5.4 archiving no longer functions. There exists a technote about that only ARJ and PKZIP is allowed for archiving, but I expect that the installation software took care of all that. It installed a "PKZIP server" for example.
When I try to archive, it starts PKZIP in a Command Prompt window, but it immediately freezes up. If I kill the Command Prompt Window, STEP7 promptly crashes too ! I get by for now by manually zipping the project directory, but what a nuissance. Has anyone heard about this, and maybe (hopefully) got a fix ?
__________________
Jesper
#2 |
![]() Join Date: Oct 2005
Jesper,
when SP3 came out? I have the latest and greatest and it is V5.4 SP2 Release K5.4.2.0 |
#3 |
Some time ago actually.
http://support.automation.siemens.co...ew/en/26578452
__________________
Jesper
#4 |
Jesper,
It must be something to do with your PC, I have V5.4 SP3 installed on 5 machines in total ( 2 PC's, 2 PG's and 1 toshiba laptop) and I have not experienced any problems archiving or retreiving projects. This doesn't help you much, does it? Paul
__________________
There are 10 types of people in this world.. Those who understand binary and those who don't! |
#5 |
![]() Join Date: Nov 2003
I don't have a problem either.
Have you done to Options>Customize>Archiving and tried setting the path for your prefered archiving software? My pull down menu gives me seven different archiving programs. |
#6 |
![]() Join Date: Aug 2005
I'm not having any problems and I have it on 3 systems
#7 |
4 PC's no problems.
Nick |
#8 |
Got the screenshot from the office circulation. Did not bother to translate it as not using V5.4
#9 |
S7Guy, it is currently set to "PKZip 8.6 (.zip)" which I think is correct.
There is a technote that says that only PKZip or ARJ is allowed for archiving, so it should be correct. I dont want to use ARJ. Sohwel, there is no similarly named subdirectory within the project directory, so that cannot be the explanation. Here is an error message that appears if I wait long enough: I shall wait until a HF arrives. Until then I will zip the projects manually.
__________________
Jesper
#10 |
A SP3.1 has arrived.
It has fixed my archiving problem.
__________________
Jesper
#11 |
You're not alone!
Jesper
Just to let you know that you're not going mad, it's not just you - we're experiencing the same problems too. A mixture of plain not working or the process takes several minutes, as opposed to the 10-15 secs it usually takes. Downloading 3.1 right now anyway. S |
#12 |
Is it possible to blame this on Rockwell, as some people are quick to jump on the RockHELL bandwagon when a new version is released that has bugs?
__________________
Work to Ride, Then Ride to Work |
#13 |
Not sure what you want to say there curly.
Anyway, I think the fix came rather quick. The only thing I am a bit peeved over is that the SP3.1 takes exceptionally long to install, and you have to install it over SP3, so you have to add the time for installing that too. If I had known, I would not have installed SP3 or SP3.1. Only if you have VISTA do I suggest that you install SP3. As far as I know there is nothing significant in SP3 apart from support for VISTA.
__________________
Jesper
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Wincc V5.1 and Step7 V5.4 | overgeo | LIVE PLC Questions And Answers | 5 | November 1st, 2006 02:51 PM |
| Step7 V5.4 opened by V5.3 | curlyandshemp | LIVE PLC Questions And Answers | 3 | October 23rd, 2006 12:43 PM |
| Step7 v5.3 SP3 and CPU 315-2 PN/DP (6ES7315-2EH13-0AB0) | Gromit | LIVE PLC Questions And Answers | 5 | September 4th, 2006 01:18 PM |
| Upgrading Step7 with SP1, SP2 and SP3 | laura | LIVE PLC Questions And Answers | 3 | July 23rd, 2006 05:25 AM |
| What's new STEP 7 V5.4 | EKBist | LIVE PLC Questions And Answers | 7 | April 28th, 2006 04:29 AM |
