This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
![]() Join Date: Oct 2007
RSlogix500 and remote desktop
on a computer thats connected to both the PLC and normal network we have RSlogix500, 5000 installed
5000 will open fine over RD but 500 gives a license error we have the license and all and it opens fine localy but not remotely |
#2 |
![]() Join Date: Feb 2006
Are you opening a second session of RSLogix500, or is it the only one open on that PC? We've seen this error before when trying to open two sessions of RSLogix500.
#3 |
If no instances of rs500 are open and I remote desktop to it I can't open it but if I already have it opened then remote desktop I can use the open instances but if I close one I can't open it back over remote desktop only localy
and we're using a common user on the computer and the console switch so the user is already loged in and it just changes to a remote session and we have a way worked out to prevent being knocked off by someone else logging in |
#4 |
Can you open two instances of the program if you are running this on the local machine? If not, then your problem is with Microsoft and they way it is trying to open the program when done using Remote Desktop. Try opening the program by right clicking RSLogix 500 and Run as the local user.
#5 |
the problem may be in the way you installed your license.
there is a network wersion and a single user version. regards, james |
#6 |
If I'm infront of the computer I can open as many as I want but if I RD to it then unless its already open I can't open it
recently I upgraded to 7.3 and now if it open it remotely I get a trial message but if I open it localy it opens fine and normal the user account used is the same as the one logged in localy and is a domain user account |
#7 | |
Quote:
its from a master disk |
#8 |
![]() Join Date: Aug 2004
Just a WAG.
In RD client before you connect, expand the Options to look at your Local Resources tab and see if Local Devices: Disk Drives is checked. Uncheck it if so. Might be that '500 is looking at your local drive for the activation files vs the computer that it is installed on. |
#9 |
Just tried that and didn't work
#10 |
![]() Join Date: May 2003
There is a know problem with remote desktop and 500 using the newer factory talk.
Here is a thread..... http://www.plctalk.net/qanda/showthr...remote+desktop
__________________
"It is the tragedy of the world that no man knows what he doesn't know - and the less a man knows, the more sure he is that he knows everything." Author Unknown |
#11 |
![]() Join Date: Dec 2006
not sure whats causing your problem but i have one main pc that runs our view se server and i also use to to make changes to the existing programm (slc 5/05). I use pc anywhere to access it and i haven't had any problems to date.
#12 | |
Remote Desktop and PCAnywhere are completely different beasts, just an FYI.
Quote:
#13 |
![]() Join Date: May 2007
Wow how freaky is this!
I had EXACTLY the same problem yesterday and asked Rockwell Tech Support what was going on. Apparently Logix 500 doesnt play nice with Windows .net framework 1.1. .net Framework 1.1 is used by Remote Desktop to manage opening and closing programs and as such Logix500 cant be opened via Remote Desktop. Their solution was to use either VNC or PC anywhere or dont close down Logix500. I tested mine and once logix is open everything works great. |
#14 | |
Quote:
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Convert a Float to String RsLogix500 | Big John T | LIVE PLC Questions And Answers | 3 | April 11th, 2007 02:05 PM |
| Remote PLC Programming | ken c | LIVE PLC Questions And Answers | 14 | October 12th, 2006 10:13 AM |
| Remote I/O Flex I/O Quick Change Tooling Fixture | TamHoNutech | LIVE PLC Questions And Answers | 1 | September 29th, 2005 05:46 PM |
